Too many sources: How Do I connect ?
tapeshc
I want to purchase the new Dared 2000A preamp, but I have four sources(CD, DVD, Tuner, TT) but this preamp has only two inputs.
Any suggestions ? how do I connect my sources. Is there are a wayout that can be used without sacrificing the Audio quality.
Please help !
Tapesh
Please help !
Tapesh
Tapesh
Tapesh
Post edited by tapeshc on
Cardas, for one, makes excellent quality "Y" connectors (1 male RCA, 2 female.) I use them with no discernable change in the quality or character of sound in my system. I purchased mine at Audio Advisor.
Mike -
Thats what I thought initialy but wont that be a problem.
I mean one can split the signal but when you are merging signal, wont it create problem with the preamp or the sources.
Short or something like that, because we are merging signal, which is basicaly electrical current, if I know it correctly ?
By any chance if I have both the sources on what would happen ?
TapeshThanks
Tapesh -
There should be no problem electrically. If you play sources simultaneously (I assume accidentally) you'll of course get a distorted output. Most preamps with multiple line stage inputs just do the same thing as an external "Y" internally.
Really??
Blue might be right, but I would not suggest it.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
It's fine to use the Y's.
If you have more than one source on, you'll hear both sources. No issues at all, as Mike stated.
Cheers,
Cheers,
Russ
Interesting, I would have never tried it out of fear of smoking something inside the pre or the output of the sources.Dodd - Battery Preamp
I'm doing this right now at work. I have two computer sources, one is a dedicated jukebox. I wanted them to both come in on the same input so that I could hear the sounds from my computer while the music was playing through the jukebox... without having to have two speaker systems.
Simply put two Y adapters on, and bingo. Now, I used cheapo Ratshack Y's, because sound quality wasn't a very big concern.
But yes, it does work, and works just fine.Ludicrous gibs! -
Depending on the sources you could damage the output device in one of them. Most probably work OK. They are mostly capacitor coupled which means DC wouldn't hurt them but the actual AC signal of one is a strong load to the other if both are on at the same time. It would be a non-issue all together if you put a resistor in series at the outputs. Of course this would never be optimum for HiFi listening.
madmax,
I'll certainly defer to your knowledge here. What is the alternative? Come off one of the inputs to a multiple jack expansion box with switch selection?
Mike -
Agreed that using a Y-connector may cause a problem, I was thinking this same thing a while back for the Dodd, Gary told me the unit cannot take the Y-connection.
I have seen some switch connectors for around 30-40 bucks, dont have a clue though how well they actually work.
RT1 -
Does the preamp have phono inputs and phono preamp?
I don't know of a good no-noise solution other than a preamp with more inputs. You could use the DVD on one input and everything else going through a second preamp (lesser quality one) with its output going into the second input.
I believe the Dared is a line stage only preamp. Hey, they're relatively cheap - gre two of them. Problem solved.
Thanks for responding everyone !
So the conclusion is, I shouldnt try merging signal, it can hurt sources.
I was just trying to bring down my investment, as we are planning to buy a house and we need money.
I thought I will sell Pass Lab X2.5 and get Dared SL-2000A, it will do two things, save money and tubes .
Buying two will still save money but what will I do for amps ?
TapeshThanks
Tapesh
