What do I have SRS, 1.2 or 1.2TL????
I've dissected enough 6510's and 6511's. The only difference between them is the extra coil winding of the 6510's. Same flabby suspension/thin spiders as the 6511's.
That makes sense. Qms and Cms are so close as to be insignificantly different, in the Polk specs.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Is it OK to hit the LOL button, just for nostalgia sake?Don't take experimental gene therapies from known eugenicists.
Gardenstater wrote: »Qms and Cms
Do you want to buy a vowel? -
Sorry, if this isn’t the place to ask but is there any way to clean or replace the clear plastic on the SL2000s?
Have all of the speakers epoxied right now. Hopefully going to get the Dynamat finished this weekend.
Caps and resistors to redo the crossovers are on order.
Its nice to keep track of everything you'r doing from here, looking forward to the finale.
From Westmass guy .RIP.
Windex, not Glass Plus, or some generic cleaner, and a lint free cloth. I use microfiber cloths instead of cotton. They clean better and leave no lint what-so -ever. Use a circular motion, and keep the cone wet by re-applying Windex to the cloth. I find it easier to clean the rubber surrounds first, to get all the brown oxidized rubber off, then use a fresh cloth for the cones. Be aware that the cones are supposed to be tacky, that's the special coating Polk applied to them. It's the reason the cloth must be kept wet until the cones are fully cleaned. The clear domes on the SL2000 tweeters can be cleaned with Windex and Q-Tips. Pour some Windex in a small cap or similar, dip the Q-Tip in, and GENTLY clean the dome. Don't apply too much pressure, just run the wet Q-Tip over the dome.VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable,
,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it! -
I tried that, is there anyway to clean behind the clear plastic?
Nope.
Gardenstater wrote: »Beachmover wrote: »Thanks again for all of the information. I feel lost with these speakers, It seems like Polk was all over the place back then.
I have the option to pick up a pair of Monitor 12s Series 2 for $300, this would get me 8 6503s to replace all of the 6510s.
Or should I wait to find some original 6510s?
Also, how do the Midwest Speakers compare to the original Polks? Would replacing those 3 missing 6510s with the new ones be a huge difference?
If you can't tell I am antsy to get these up and running.
I would jump on those M12. If any are locked or rubbing ask for some $ off that price. That would even let you load up one cabinet with the MW6503 and the other with MW6510 and see if you hear the difference. Remember, the MW6510 were NOT the original drivers as far as I have been able to determine. Page 12 of the SDA Handbook:
@Lerjebrink 1.2's Wooo Hooo. Lots of great info in this thread.party time.VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable,
