What do I have SRS, 1.2 or 1.2TL????
I've dissected enough 6510's and 6511's. The only difference between them is the extra coil winding of the 6510's. Same flabby suspension/thin spiders as the 6511's.
That makes sense. Qms and Cms are so close as to be insignificantly different, in the Polk specs.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Is it OK to hit the LOL button, just for nostalgia sake?Don't take experimental gene therapies from known eugenicists.
Gardenstater wrote: »Qms and Cms
Do you want to buy a vowel? -
Sorry, if this isn’t the place to ask but is there any way to clean or replace the clear plastic on the SL2000s?
Have all of the speakers epoxied right now. Hopefully going to get the Dynamat finished this weekend.
Caps and resistors to redo the crossovers are on order.
I tried that, is there anyway to clean behind the clear plastic?
Nope.
