What do I have SRS, 1.2 or 1.2TL????
  • Gardenstater
    Gardenstater Posts: 4,991
    xschop wrote: »
    I've dissected enough 6510's and 6511's. The only difference between them is the extra coil winding of the 6510's. Same flabby suspension/thin spiders as the 6511's.
    That makes sense. Qms and Cms are so close as to be insignificantly different, in the Polk specs.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,932
    Is it OK to hit the LOL button, just for nostalgia sake?
    Viking64 Posts: 7,836
    Qms and Cms
    Do you want to buy a vowel?
  • Beachmover
    Sorry, if this isn’t the place to ask but is there any way to clean or replace the clear plastic on the SL2000s?
    Have all of the speakers epoxied right now. Hopefully going to get the Dynamat finished this weekend.
    Caps and resistors to redo the crossovers are on order.
  • Unknown
    edited October 30
  • Beachmover
    I tried that, is there anyway to clean behind the clear plastic?
    billbillw Posts: 8,371
    Nope.
  • Unknown
    edited November 12
