Advice needed: Desoldering components from a speaker crossover
Hi everyone—I’m replacing components on a pair of Polk Monitor 5's crossovers and could use some advice on removing the old solder without damaging the board. I’ve attached a photo showing its current condition.
In the past I have done some basic repairs/replacement on much smaller PCBs and have not worked before with such large blobs of solder to remove.
I have:
- An adjustable-temperature soldering iron
- Solder and flux
- A manual solder sucker
- Desoldering braid
A few questions:
- What temperature and tip shape would you recommend for these joints?
- Should I use the solder sucker first and braid only for cleanup?
- How do I free a component lead that still seems attached after removing most of the solder since the leads are long and folded over the board?
I’m trying to avoid overheating the board or lifting the copper pads. Any practical tips would be appreciated. Thanks!
Main music system:
Sunfire Signature Amp - Emotiva TA1 (premap) - Fluance RT85 turntale with Ortofon 2M Black - Clearaudio Basic Plus Phono Preamp - Panamax MAX 5100 - Wiim Pro streamer - JBL PSW1000 - Polk Monitor 5
    billbillw Posts: 8,346
    Some people like solder suckers, but I prefer to use the braid. If you have a knife edge tip, that will be most effective because you can lay it sideways on top of the braid. The board will be fine as long as you keep the temp a low as it takes to melt the solder. This is probably well before before lead-free solder was used, so it shouldn't need too much temp to flow. I'd shoot for 360-375F on the temp. Clean the tip often.
  • Sosublime
    Sosublime Posts: 20
    Thank you Bill!
    Main music system:
    Good luck and don't forget to stay ventilated.
    Another member said that you might want to go hotter and there is no worries about overheating the pads since the copper is so thick, it will dissipate heat well. He suggested 500F, but just try until it liquefies fairly quickly.
  • Gardenstater
    Gardenstater Posts: 4,983
    Solder suckers are something I have had mixed results with. I think there are a lot of cr appy ones out there and a teflon tip with a proper fitting plunger is mandatory. I always wanted to go the next step if I started doing this work more frequently and get one that integrates the soldering tip with the solder sucker in one unit so there is no question of the solder staying molten or not. I think those ones just have a suction bulb.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    SCompRacer Posts: 9,404
    edited October 17
    I've used wick and one shot solder suckers. Apply some rosin flux when using wick or a one shot sucker. Flux helps promote capillary flow.
    There are times I do quite a bit of desoldering and prefer to use this Hakko FR-300. Adjustable temp, various size interchangeable nozzles. Constant heat when on. Depress the button for vacuum. Pricey for a one time user.
    If you have a lead stuck to pcb, sometimes you have to heat it and use a tool with edge that can lift it away and turn it. A small regular screw driver will work. Whatever you use it should have a handle as heat travels.
    IIRC the polk boards had a thick layer not easily pulled off. Older electronics gear with small traces can be torn away from pcb trying to move a stuck lead. Sometimes I run into multiple leads on one trace that need to be seperated.
    edited October 17
    Just curious if you were removing the polyswitch (thermal fuse) in the tweeter circuit? I don't recall it being mentioned in your other thread. It's typically done to improve high-frequency clarity and remove potential distortion. Without it, if you overdrive your amp and it clips, you can fry the tweeter.
    If you do eliminate the polyswitch, folks commonly replace it with a .5 ohm resistor. I just added .5 ohm value and used a 2.5 ohm resistor in place of the OEM 2 ohm value in my 7C xover.
    If you eliminate polyswitch and use a 2.5 ohm bypass the small pad and connect like this. No need for a small jumper where polyswitch was.
  • gmcman
    gmcman Posts: 1,887
    Only doing a couple jobs, then solder wick works fine. For a list of projects a desoldering tool like the Hakko or similar is a game changer.
  • Sosublime
    Sosublime Posts: 20
    Thanks everyone for their advice. Here is what I found worked best:
    • Let iron heat up
    • Place iron on tail that was pressed against the board until solder around the tail has melted
    • Take a metal pick and pry tail off of board
    • Continue heating tail until it can be pulled through the board
    • Use braid to remove extra solder from board
    My flaw was trying to remove the solder with the tail still on the board. I could remove most of the solder, but it was still stuck to the board.
    The new caps and resistors sound phenomenal! I forgot to take picture of the crossover when it was on my desk.
    Main music system:
    Very good! Do you have a hot glue gun? Zip ties work too. It helps to dampen the larger capacitors so vibrations won't stress and break leads off.
  • gmcman
    gmcman Posts: 1,887
    SCompRacer wrote: »
    Yeah, you would benefit from finding a way to securely mount them to the board other than the 2 leads. At least keep them from vibrating and having to hold themselves in place by the leads alone.
  • Sosublime
    Sosublime Posts: 20
    I went back and secured these with hot glue and zip ties. Thank you for all of the feedback, I appreciate how generous everyone is here with their advice and guidance. whraht00vmqp.jpeg
    Main music system:
    That should hold up. Enjoy them breaking in!
