Advice needed: Desoldering components from a speaker crossover
Hi everyone—I’m replacing components on a pair of Polk Monitor 5's crossovers and could use some advice on removing the old solder without damaging the board. I’ve attached a photo showing its current condition.
In the past I have done some basic repairs/replacement on much smaller PCBs and have not worked before with such large blobs of solder to remove.
I have:
- An adjustable-temperature soldering iron
- Solder and flux
- A manual solder sucker
- Desoldering braid
A few questions:
- What temperature and tip shape would you recommend for these joints?
- Should I use the solder sucker first and braid only for cleanup?
- How do I free a component lead that still seems attached after removing most of the solder since the leads are long and folded over the board?
I’m trying to avoid overheating the board or lifting the copper pads. Any practical tips would be appreciated. Thanks!
    billbillw Posts: 8,271
    Some people like solder suckers, but I prefer to use the braid. If you have a knife edge tip, that will be most effective because you can lay it sideways on top of the braid. The board will be fine as long as you keep the temp a low as it takes to melt the solder. This is probably well before before lead-free solder was used, so it shouldn't need too much temp to flow. I'd shoot for 360-375F on the temp. Clean the tip often.
  • Sosublime
    Sosublime Posts: 11
    Thank you Bill!
    Good luck and don't forget to stay ventilated.
