old Polk Powered Subwoofer-no model number
The downfacing 8" speaker rubber surround has cracked. I can find generic replacement kits, but wonder if there are POLK OEM parts. Also, wondering if I should consider replacing the bare speaker, but with what? Appreciate any help.
Answers
  • stownsley56
    Here is a photo of the back
  • gp4jesus
    gp4jesus Posts: 2,025
    edited October 12
    PS 120* maybe? Mine had nothing indicating model, etc. Post more pics to the many more knowledgeable to solve the mystery.
    It’s looks similar to mine*. Difference: the driver basket & magnet are in the closure, downward firing. Is it ported? Mine has 2, diameter maybe 2” but I haven’t examined for some time.
    *all connected w/Premiere ICs
  • stownsley56
    Some additional photos. Subwoofer was purchased around 1997 as part of a 5.1 surround speaker package. 59bdw3ysz2uy.jpg
    billbillw Posts: 8,346
    I don't think you will find oem parts for that. Options are buy a similar subwoofer from someplace like PartsExpress, Madisound, etc., or just replace the whole thing with a new modern subwoofer, which would probably blow you away with the improvements. The subs in those package units were pretty weak overall.
  • stownsley56
    @billbillw --thanks for the suggestion to look at new subs. Took a listen of some new options that are SO much better.
