Bruce and MIT - No more as we know it.
  • Unknown
    edited September 7
    nooshinjohn Posts: 26,184
    edited September 7
    The L800's present an exceptionally detailed soundstage that suits itself well to the more intimate music styles I have come to enjoy... clubs and small venue recordings. They are able to grow the room a bit with larger venues which is also nice. They image far better than the TL's did in my space. If an artist is singing slightly left of center as was when performing with a group, that is where he appears in the space. Nothing is forced to the center, which really allows the speakers to present a true and believable performance.
    I am listening to The Eagles "Live on MTV" right now and this recording really shows what they are capable of.
    xschop Posts: 5,931
    ptrooper wrote: »
    Agreed ,Their tweeter position definitely lifts the sound stage,This is what they were designed to do. Xschop always mentions building a stumpy version. lmoa.
    I only mentioned it because it'd be the only way to trump the Monoliths.
    That, or put a Lazy-Boy recliner on a taller platform lol
    F1nut Posts: 52,406
    That issue with the 1.2TL is a major design flaw and why the 2.3TL is the better speaker.
    xschop Posts: 5,931
    According to the regurgitated ai drivel, TL designates they were designed for "Tall Listeners" lmao.
  • Unknown
    edited September 15
    F1nut Posts: 52,406
    Yep, it's like squatting down in the orchestra pit instead of sitting in the auditorium seats.
  • Unknown
    edited September 15
    pitdogg2 Posts: 27,921
    edited September 15
    My personal opinion, it doesn't matter much.
    I find the 1.2tl's and original SRS tends to exaggerate the size of instruments.
    Like I said my opinion. Over the years I've heard them set up in many different rooms, only one room made them listenable for extended period. That room was so dead, but it worked for the 1.2tls.
  • motorstereo
    motorstereo Posts: 2,428
    I vastly prefer my 1.2tls over the 2.3s they replaced. But my seating isn't conventional in a recliner or a sofa as it's a hassle for me to get up out of. Standing works very well or when I do sit and listen it's on a wooden bar stool about 12' back which sits up high and is the right height for the tl's tweeters. The room is good sized and a bit on the lively side. A fair amount of speakers have come and gone here in the 15 years I've owned them and nothing has come close to dethroning the 1.2s no matter how I've tried.
    xschop Posts: 5,931
    For you squatties, grab ya one of these and your favorite snacks and beverages...
  • Unknown
  • Unknown
  • Unknown
    edited October 13
