Fuse for Peerless Tweeters
Does anyone know why the specified fuse for Monitor 7's and 10's with Peerless tweeter is 1A, but for the first-gen Monitor 11 the spec is 0.75A?
    pitdogg2 Posts: 27,921
    It is the same for all 1amp fast blow.
  • motorcityguy
    But, according to Polk Monitor 11 owner's manual, "correct" fuse for THIS model is 0.75A, not 1A. In fact, Polk is rather adamant about it. (See screen shots from owner's manual.)
    I admit it is puzzling to me, since the Peerless tweeter is identical to Monitor 10 & 7, in which 1A fuse is specified.
  • Gardenstater
    Gardenstater Posts: 4,991
    Yeah I remember puzzling about that myself. The Peerless are the usual 8 ohm ones right? I mean they made 4 ohm ones as well.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • motorcityguy
    Correct. They are (nominal) 8ohm Peerless.
    edited August 27
    Well, use the .75 amp fast blo. All the 7's or 10's have been 1 amp fast blo as well as my SDA 1 signatures.
    If you do a search here, you'll find most cases suggest 1 amp fast blo.
    https://forum.polkaudio.com/discussion/166860/fuses-on-vintage-speakers?utm_source=community-search&utm_medium=organic-search&utm_term=speaker+fuse
  • motorcityguy
    motorcityguy Posts: 71
    edited August 27
    Yessir! That's the plan. But I was curious about the reasoning behind Polk's deviation from their usual 1A fuse. Not that everything Polk ever did makes sense.... But just thought there might be a technical reason that I was unaware of.
    It is kind of strange, it's not like they were different peerless tweeters. The SL1000 also used the 1 amp fast blo.
  • Gardenstater
    edited August 28
    I'll take Mysterious Polk Anomalies for $200 Alex 🤣
    The circuit is definitely interesting. I wish I was better at analyzing crossovers. It looks like a pretty standard 2nd order high pass for the tweeter but unlike all the others I've seen from Polk, there is no series resistor for the Peerless whatsoever and it is usually a fairly high value. Could that be a clue as to why a lower amperage fuse, along with maybe the speaker not being super efficient (I need to try to find the dB rating)? Another weird thing about this hand sketched schematic is that it does not show the location of the fuse but the manual specifically says it is for the tweeter only:
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    Well according to this anyways, the RTA 11 was pretty darn efficient at 93dB. So that fuse probably has to be a low valued one because of the total lack of any series padding resistor for the Peerless Tweeter. It would probably have to be even lower if it wasn't for that sneak current through L4 and C2 to Driver #1 and Driver #2, which might be some sort of notch filter. The fuse would be located between that node in the schematic and C1.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • motorcityguy
    edited August 28
    The circuit is definitely interesting. ...unlike all the others I've seen from Polk, there is no series resistor for the Peerless whatsoever and it is usually a fairly high value. Could that be a clue as to why a lower amperage fuse...?
    That's an interesting observation. Looking at the schematics for the more common Monitor 10 & 7 models, I do see that they use a resistor upstream of the tweeter, whereas the M11 doesn't appear to have one. Maybe you're onto something!
    Most certainly, I will install the Polk-specified 0.75A fast-blow fuse, before firing up these bad boys for the first time. Btw, when I received them, both fuses were not only a whopping 3A, but were also "slow-blow"!! LOL, no wonder the original Peerless tweets had failed!!
