When stacking subs
Willow
Willow Posts: 11,339
how do calibrate the 2 and what should I do/not do ?
Post edited by Willow on
  • PolkThug
    PolkThug Posts: 7,532
    edited March 2005
    I calibrate mine as if they are one sub.
  • tryrrthg
    tryrrthg Posts: 1,896
    edited March 2005
    Here's how I would do it.
    Turn the sub level on your AVR to zero. Then turn one sub on and calibrate it using the volume knob on the sub. Then turn that sub off and do the same thing with the 2nd sub. Then turn both subs on and calibrate both of them by lowering the sub level on your AVR.
  • Willow
    edited March 2005
    thanks I'll try that
