When stacking subs
Willow
how do calibrate the 2 and what should I do/not do ?
Post edited by Willow on
Here's how I would do it.
Turn the sub level on your AVR to zero. Then turn one sub on and calibrate it using the volume knob on the sub. Then turn that sub off and do the same thing with the 2nd sub. Then turn both subs on and calibrate both of them by lowering the sub level on your AVR.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
thanks I'll try that
