Looking under the hood
How about some open reel innards. At least Ken may appreciate it…
Otari MX-5050 BIII-2 (1/4" tape two track pro deck), 1995 manufacture date. Otari Electric Co., Ltd. was founded in 1965 by Masayuki Hosoda, a former TEAC engineer. Three speeds, 3.75, 7.5 or 15ips. Set to default 7.5/15ips. Easy to bias for different tape formulations with built in 1kHz and 10kHz oscillators and front panel bias adjustments. Custom wood sides and footers added. Also available with optional rack/stand mounts.
Switches on rear for two output levels, IEC or NAB equalization and three reference flux settings, 185, 250 or 320 nWb/m. 320 would be used for hot mastering levels with high-output, low-distortion modern tape formulations. Rear cover removed.
Easy access design for service/repair with hinged panels, captured screws. Nichicon caps.
Three motor with direct drive capstan.
No skimping on electronics. Nichicon caps used throughout including Fine Gold.
Easy to remove (three screws) plug in head block. The jumpers/holes in PCB at right were for an optional 2/4 track switch with 4 track head installed so the 2 track deck could play (but not record) a 4-track tape.
The BIII model offerings. Some were console designs. A BQIII would be a 1/4" tape four track deck.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Very cool. Thank You
The Otaris are nice workhorse decks.
Adjusting the bias on my recently picked up 535ii. Nick-named by some as "the little sledgehammer" and I tend to agree. It's not the smoothest amp, but it is very dynamic and fun to rock out with.
See profile for rigs. Nothing else here. -
Could that be said for all Adcom amps? I have a 555 (MkI?) in storage, and remember it sounding kind of like a muscle car kind of amp. It's a great intro amp, and perfectly suitable for Polk SDA speakers needing a common ground connection.
I also have a GTP-500 preamp/tuner to go with the power amp, and this combo really deserves to be used in a good home."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Looks similar to my my CTC BBQ, also by John CurlCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
John Curl had stuff to do with Adcom? I thought he was the Parasound guru.
I thought most Adcom was Nelson Pass designs -
You are correct. Nelson was behind the Adcoms. Both men designed great stuff though and their over built designs has more similarities than differences.See profile for rigs. Nothing else here. -
I picked up this cool old Hickok digital multimeter with a nixie tube display at the local thrift store today.
I need to replace 2 electrolytic capacitors in the power supply board and this will be ready for service again.
D
Enjoying the journey while never attaining the destination. -
Update! I replaced two old electrolytic capacitors in the power supply and this thing is ready for another 55 years of service! From a time when things were:
built to last!
motorhead43026 wrote: »
Bi-wired the schnorkel!Stan
Main 2ch:
HT:
Other stuff:
The beast must breathe 💪🏼💪🏼
HP 5316a with options 003 (adds a 1 GHz C-Channel input, extending the instrument's standard 100 MHz frequency measurement range up to 1 GHz) and 004 High-Stability Oven Timebase OCXO or heated clock oscillator.
Tenma 72-450 (single channel) and 72-1040 (dual channel) AC millivolt dB meters. The two channel comes in handy calibrating a tape deck. No swapping RCA cables between R and L channels. You'd have to buy a very pricey Digital Multimeter that would display accurate ac millivolt rms voltages above 1kHz like these do. Tenma were rebadged GW Instek. GW Instek = Good Will Instruments which is a respected brand.
72-450 single channel.
72-1040 dual channel.
Needed slight calibration on one channel, slightly off at .775mV rms (0 dBu/dBm, the lower scale). The upper scale is dBV, 1v rms = 0dB. So far, all the tape decks I've calibrated state in SM 0dB = .775mV rms.
After calibration.
