Looking under the hood
1…373839404143»
    billbillw Posts: 8,371
    Adjusting the bias on my recently picked up 535ii. Nick-named by some as "the little sledgehammer" and I tend to agree. It's not the smoothest amp, but it is very dynamic and fun to rock out with.
  • jdjohn
    jdjohn Posts: 3,462
    Could that be said for all Adcom amps? I have a 555 (MkI?) in storage, and remember it sounding kind of like a muscle car kind of amp. It's a great intro amp, and perfectly suitable for Polk SDA speakers needing a common ground connection.
    I also have a GTP-500 preamp/tuner to go with the power amp, and this combo really deserves to be used in a good home.
  • dorokusai
    dorokusai Posts: 25,661
    Looks similar to my my CTC BBQ, also by John Curl
    pitdogg2 Posts: 27,918
    edited August 15
    dorokusai wrote: »
    John Curl had stuff to do with Adcom? I thought he was the Parasound guru.
    I thought most Adcom was Nelson Pass designs
  • Conradicles
    Conradicles Posts: 6,437
    dorokusai wrote: »
    You are correct. Nelson was behind the Adcoms. Both men designed great stuff though and their over built designs has more similarities than differences.
  • newbie308
    newbie308 Posts: 849
    I picked up this cool old Hickok digital multimeter with a nixie tube display at the local thrift store today.
    I need to replace 2 electrolytic capacitors in the power supply board and this will be ready for service again.
  • newbie308
    edited August 24
    Update! I replaced two old electrolytic capacitors in the power supply and this thing is ready for another 55 years of service! From a time when things were:
    built to last!
  • skrol
    skrol Posts: 3,500
    Bi-wired the schnorkel!
    Stan
    Main 2ch:
    HT:
    Other stuff:
    The beast must breathe 💪🏼💪🏼
    SCompRacer Posts: 9,408
    HP 5316a with options 003 (adds a 1 GHz C-Channel input, extending the instrument's standard 100 MHz frequency measurement range up to 1 GHz) and 004 High-Stability Oven Timebase OCXO or heated clock oscillator.
    edited August 25
    Tenma 72-450 (single channel) and 72-1040 (dual channel) AC millivolt dB meters. The two channel comes in handy calibrating a tape deck. No swapping RCA cables between R and L channels. You'd have to buy a very pricey Digital Multimeter that would display accurate ac millivolt rms voltages above 1kHz like these do. Tenma were rebadged GW Instek. GW Instek = Good Will Instruments which is a respected brand.
    72-450 single channel.
    72-1040 dual channel.
    Needed slight calibration on one channel, slightly off at .775mV rms (0 dBu/dBm, the lower scale). The upper scale is dBV, 1v rms = 0dB. So far, all the tape decks I've calibrated state in SM 0dB = .775mV rms.
    After calibration.
