Can someone tell me what model these are ?
captainmike
No model label that I can find
Best Answer
This is what I found:
Just called Mini Monitor, but we know that is not the same as the really old Mini Monitor that had a Peerless tweeter and passive radiator. So perhaps "new MiniMonitor" is correct. @captainmike Can you verify the dimensions with the catalog page above?
Answers
I opened it up and on the inside of the speaker terminal it is marked CS150
But this is not a center channel
So it must have been a model to go with the CS150 but I do not know what that model is -
Monitor 4 maybe.Most people just listen to music and watch movies. I EXPERIENCE them.
I believe that is the “New Mini Monitor”.
They were probably something that came with a mini system back in the 1990s-early 2000s time-frame. I think I remember Onkyo and possibly Denon both sold mini systems that included Polk "branded" speakers. Nothing you'll ever find in Polk's catalogue.
I have already provided the correct answer. I have two of these in the Razor Crest. I even have the manual somewhere.
The are the New Mini Monitor. Nothing to do with the original Mini Monitor line, nor similar in any way.
The_Mandalorian wrote: »I have already provided the correct answer. I have two of these in the Razor Crest. I even have the manual somewhere.
You're pretty cocky for someone named after a Star Wars character.
