Can someone tell me what model these are ?
Best Answer
    billbillw Posts: 8,073
    edited August 13 Answer ✓
    This is what I found:
    Just called Mini Monitor, but we know that is not the same as the really old Mini Monitor that had a Peerless tweeter and passive radiator. So perhaps "new MiniMonitor" is correct. @captainmike Can you verify the dimensions with the catalog page above?
Answers
  • captainmike
    I opened it up and on the inside of the speaker terminal it is marked CS150
    But this is not a center channel
    So it must have been a model to go with the CS150 but I do not know what that model is
    Tony M Posts: 11,950
    Monitor 4 maybe.
  • The_Mandalorian
    I believe that is the “New Mini Monitor”.
    pitdogg2 Posts: 27,734
    Tony M wrote: »
    Monitor 4 maybe.
    Nope.
    edited August 13
    They were probably something that came with a mini system back in the 1990s-early 2000s time-frame. I think I remember Onkyo and possibly Denon both sold mini systems that included Polk "branded" speakers. Nothing you'll ever find in Polk's catalogue.
  • The_Mandalorian
    The_Mandalorian Posts: 10
    edited August 13
    I have already provided the correct answer. I have two of these in the Razor Crest. I even have the manual somewhere.
    The are the New Mini Monitor. Nothing to do with the original Mini Monitor line, nor similar in any way.
    Viking64 Posts: 7,755
    You're pretty cocky for someone named after a Star Wars character. :p
