End of the line, boys....
  • rebelsoul
    rebelsoul Posts: 802
    Who here hasn't called it "the end of the line" at some point or even multiple times? My end of the line or game over happened in 2011 when I brought home my 1.2tls. It wasn't long before that game over turned into a new beginning.
    I have about 12 times .I just told my wife that's it with new dac and streamer
  • Geoff4rfc
    Geoff4rfc Posts: 3,062
    Funny thing, I started this hobby (obsession) right before I got married (now ex-wife) back in 2011. She watched me go from Monitor series to RTiA series and then LSiM series. Upgrading cables, AVRs to AVPs, adding one amp at a time....etc etc. All through that upgrade process, I'd tell her, "I just need this one more thing and I'm done". The look she gave me was, "either you're retarded or you think I am", followed with, "Uh huh, at least for the next five minutes".
    Now, 15 years later, "one more thing and I'm done" has finally been realized lol. Like the OP says, I'll need to hit the lottery to go above and beyond where I'm at.
    Good on you John!!
    Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
    EndersShadow Posts: 17,765
    Geoff4rfc wrote: »
    As someone who watched you through that entire progression I simply call “BS” 🤣
  • Geoff4rfc
    Geoff4rfc wrote: »
    So true Dan, you've known me since the Monitor days........
  • Emlyn
    Emlyn Posts: 4,920
    I've reached the point where I don't really need anything new for a main two channel system so I just consider buying things like the Eversolo T8 music streamer then pat myself on the back for waiting when a few months later they put out a new and better T10 model. Now I'll wait for a T12 model! And I won't buy that if it becomes available either.
    I've had an Eversolo DMP-A8 in use for a couple of years and find that to be adequate enough. Diminishing returns to bother getting something else.
  • Geoff4rfc
    edited June 18
    Emlyn wrote: »
    Right!! The individual model update scenario is the worst. The difference between the Denafrips Pontus 12th and 15th are pretty substantial. My timing on the Venus 15th over the 12th was good as the difference there is also substantial.
    I can see updating a specific model in one's set up if one chooses without succumbing to the upgrade bug by going to the next bigger and better unit.......like I just did with my AVP :D
  • Upstatemax
    Upstatemax Posts: 2,865
    Emlyn wrote: »
    Yeah, my A8 won't be going anywhere for a good amount of time.
    The A10 being 2x the cost, and IMO for music, goes backwards with the swap to ESS DACs, is an easy pass for me.
    If I was using my A8 as a full time preamp, I could see self justification for some type of an upgrade on the sooner end. However, for critical listening it's only functioning as a streamer/dac, dumping the information to my tube preamp.
  • Unknown
    edited July 19
  • Geoff4rfc
    1ptrooper wrote: »
    nooshinjohn. these are the end game with the duelund sda’s You should try them !
    Hey Doug, I've pretty much reached my end game as well. With a lot of help from you to get me there!!!
    Hope things are well, good to see you on here!!
    nooshinjohn Posts: 26,181
    I saw this thread popped up again... Nearly 6 months in and I am happy to say I have only browsed USAM and the 'Gon only a couple times. no temptation whatsoever out there.
  • Conradicles
    Conradicles Posts: 6,437
    You suck John :D
  • skipshot12
    skipshot12 Posts: 2,173
    Quitter.
    treitz3 Posts: 20,367
    Oh, he may have made it this far. I'll give him that. He is itching and pounding pud to something other than a shift in hobbies.
    (car)
  • joecoulson
    joecoulson Posts: 4,986
    Shift in hobbies - Bingo!
