Deck re-decking just finished up.
pearsall001
Well the wooden deck finally had to go. We bought the house in 1992 & it was there already, 34yr life span is pretty good! It didn't owe me anything.
In 2002 I had a pool put in & using Trex had a big deck built around it.
I kept the lower wooden deck because it still looked beautiful.
The lower deck now was re-decked using Trex in a picture frame design and. It came out really, really nice. All in all the 2 combined decks are approx. 900 sq ft. We had many large pool parties when the kids were young & especially during baseball season. Not so much anymore.
Looking great!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Well done!👍 💪🤘
Nice and clean....looks Great! Are you for hire?
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Beautiful.
Looks great! Be careful with bare feet and sunshine, it gets 🔥🔥
I have nothing but good things to say about trex.
It should be noted for an exposed structure your joist should be 12 inch on center.
My front porch is 16 but is covered and it's been 6 years no issues.
I built a crawl space door 15 years ago that still looks awesome.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Trex is definitely a top notch product. I stayed with Trex because the Trex pool deck is now 24yrs old & still looks fantastic! No issues with it at all after all the years.
It took me quite awhile to feel comfortable with the contractor I went with. I had quotes that left me speechless to say the least.
Pretty much the deck was done by one guy...Lucas. The man was so maticulus & it really shows in the final outcome. Happy as a clam!!
What a beautiful and functional outdoor space. Love it.Things work out best for those who make the best of the way things work out.-John Wooden
You couldn't afford me. Lol!!
Nice & clean is what I was shooting for & very pleased with the results.
Mad skills on display there, great job.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey.
Religion began when the first scoundrel met the first fool……….Voltaire. -
My Trex deck is almost 30 years old and it's still fabulous. I think the only thing I did to it was after 20 years I pressure washed it.Gustard X26 Pro DAC
I used to use a pressure washer also but got tired of the hassle with that thing.
Now since I use liquid chlorine for my pool & figured why not try that for cleaning. Man oh man I should have done that 20yrs ago. I make a 50/50 mix with water in a gallon pump sprayer. I use it on everything...Trex, aluminum siding, all pool furniture, concrete etc, etc. You name it it works like a charm.
Simply hit whatever you want to clean with the hose, spray the chlorine on & let it set for just a few minutes then hose it off...looks like you just bought it.
Rather inexpensive also about 20.00 for 5gal at the pool store.
Doesn't the run off hurt plants, grass, etc? Certainly can't be great for the environment............not that there aren't a million other things too. I'm trying to switch to a less harmful, bug and weed killer just to do my minuscule part to pollute less.
Genuinely curios, not judging.
I've been using pool chlorine for cleaning for about a good 15yrs now & it had zero effect on plants, flowers, shrubs, grass etc etc... when done right it doesn't stay in contact long enough (my take on it anyway) plus it's getting hosed off within a few minutes.
I do use Spruce natural weed killer that works pretty darn good. Kills those suckers in a few hours.
I try to keep things simple but they have to work & get the job done.
Don't forget the chlorine is only being used on non living items & trust me it simply works for making cleaning quick & easy.
Try the Spruce for your weeds. Safe for the environment & actually works. -
Does the Spruce kill grass?
They make two products Spruce weed killer & Spruce weed & grass killer. The one I have is just their weed killer. I only use it on weeds in mulch beds & river rock beds.
I figured out what to do with the extra Trex materials after the redecking was done. It turned out well...a 28" x 8' serving table, plenty of room for the adult beverages!! Blends in nicely with the deck design. -
Great job!
Conradicles wrote: »Great job!
Thanks. It actually turned out better than I invisoned. Definitely an upgrade over the 6' folding table that I was previously using. -
Chlorine, especially stuff used for pools, will break down very quickly in UV light. Especially if it doesn't have any organic compounds to react with. So even in undiluted levels, it gets pretty inert pretty quick when not in a controlled environment with reaction stabilizers like a pool or hot tub or something. That's why you have to constantly keep up with it in your pool.
It is a naturally occurring element and is usually inert in "the wild" because it bonds readily with organic compounds which is how it does it's sterilization thing. Because of its high level of reactivity, all chlorine in the Earth's crust is in the form of ionic chloride compounds, which includes table salt. Chlorine doesn't exist on it's own without stabilization. The stuff in bleach and pool chemicals has been refined and stabilized for use as a cleaner/disinfectant. The sterilization action can create other compounds like chloramines which give that "chlorine smell" to a pool. That means the chlorine has already done it's job and your filter is going to filter all of it out. But I'm not going to get in to pool care and chemical management.
Chlorine, even diluted, is still bleach. Both are sodium hypochlorite and the main differences between the pool chlorine and the household cleaner is that pool chlorine has a higher level of active chlorine in it that isn't bound to organic compounds. It's also significantly more concentrated than household bleach. Household bleach can also have other compounds in it like surfactants to make it less prone to evaporation so that you can actually clean with it and it has a low surface tension so it actually works in your laundry.
Pool chlorine has less compounds in it for binding to the chlorine leaving a higher level of active chlorine in it so it's more effective as a sterilization chemical. It also tends to have UV stabilizers in it so it lasts long enough to do it's sterilization thing.
So, that said, be careful with the pool stuff because it is very caustic compared to regular bleach and it can bleach certain finishes, it is terrible for cleaning wood that is unfinished unless you're doing mold abatement and it can deteriorate certain materials like paints or varnishes too. Certain plastics have finished layers that the chlorine will degrade or there are likely UV protective coatings that the chlorine can damage too. It will degrade bare wood, raise grain and bleach it to the point where you'll need to sand it and refinish it to fix the damage and protect it from the elements again. That's due, mainly because of the concentration levels found in pool chlorine. So dilution is a must if using the pool chlorine as a cleaner. I haven't seen the plastic decking get damaged by bleach, it's PVC so it's inert but, like I said, pay attention the finishes as the finished layers could be affected even if the main material isn't.
I know TREX recommends certain cleaners for their stuff. TimberTech does too. TREX officially says to use Dawn dish soap and a mop. They also say to use baking soda and vinegar but I'm not sure why as those two will react with each other and cancel each other out so that seems like stupid advice to me. But both TREX and TimberTech recommend cleaners based on oxalic or phosphoric acid for stubborn stains or heavy cleaning needs. So stuff like deck brighteners or vinyl fence cleaners will be what they are recommending. TimberTech actually sells their own deck cleaner for their products too.
As far as hurting the environment, it'll change soil pH for a little bit after use but it will break down or bind with organic compounds in the soil and the next rain it will be so dilute it won't even register on a soil test as more than a salt. It does hurt the soil biome but since it doesn't linger in reactive states for a significant amount of time, the biome will recover.
Otherwise, the new deck looks great!
Now come do mine!Expert Moron Extraordinaire
Hey John,
How's things going for ya. Pretty good I hope.
Yeah the pool chlorine is definitely potent stuff but it simply works. Plus it's dirt cheap compared to the stuff in the big box stores. I've been using it for my spring cleaning for over 20yrs & never had an issue.
In fact all of the vendors I had come in for a price quote on on redecking project couldn't believe that the upper level Trex deck & rainings were 24yrs old. I only clean it once a year right before I open the pool. I'll probably continue the routine with the new deck this spring also. I have a lot of Azek around the pool too so I'll to see if that might need a different kind of cleaner. That stuff ain't cheap.
Have you been firing up your smoker lately? I still remember the Polk Fest at your other house & your exquisite smoked goodies you had going!! My mouth is still watering. That was a great day to say the least.
Yeah, all of it is expensive!
I was just doing my due diligence and trying not to give bad advice. I, too, was worried about chlorine runoff from the pool with it being so close to the lake and one of the environmental guys dealing with the Sherwin Williams SuperFUNd site on the other side of town told me a lot about chlorine and basically said not to worry too much. Algaecides and certain pH chemicals are far more damaging.
I had the smoker running back in May and early June on a couple of things but we were in Texas for most of July and it's been just too damn hot to doing anything with it lately. Plus with the bad drought, there's been fire restrictions. They should be lifted now, though so maybe something soon.Expert Moron Extraordinaire
We did the same type of picture frame look 12" on center and the hidden fasteners using TimberTech. Also very happy with the look but man does that stuff get hot on your feet in full sunshine. Deck carpet helps a lot. Not missing the tedious task of restaining...$$ well spent.Yep, my name really is Bob.
Rogue Audio Conus Magnum iii Dark, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
It sure does get hot but flip-flops take care of that along with carpeting around the ladder area. And definitely worth the $$.
