Denon POA 2400
leroyjr1
Any good? Can pick it up for $125. Just something different to try out and play around with.
Post edited by leroyjr1 on
Seems like a great price although I have not heard that particular model.
There is a parasound A51 on audioadvisor for a good price, I remember you were thinking about picking one up..
I have been using a POA-2400 for over twenty years. I've also had Parasound, Adcom, NAD, and Rotel amps over the years. The POA-2400 is the only one that's still here...
$125 is a steal, assuming it works. The only thing I never liked about it were the odd binding posts, which I finally took care of a couple of years ago. -
Looking for the Halo A52. 125 watts per channel is more than enough for my efficient speakers. -
Thanks for the info. -
Good price!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
@WilliamM2 was there any cutting involved to make those fit? (the 5 way binding posts?)
If you look at the first pic, the original posts mount to a black plastic piece. I did not have to cut the chassis, bit I did have to drill holes in the plastic part larger, it removes with two screws.
I think, it's been 19 years since I did that. I know I didn't have to cut any metal. I also don't know where to get those posts anymore. -
Post a reply to a 15 year old thread asking a specific person a specific question and said person actually answers the question…the same day, no less. Impressive!Things work out best for those who make the best of the way things work out.-John Wooden
Good eye! Funny stuff! 😁
I would not have remembered the answer to the question after 15 years, myself!
Brian
