Denon POA 2400
leroyjr1
leroyjr1 Posts: 8,785
edited January 2011 in Electronics
Any good? Can pick it up for $125. Just something different to try out and play around with.
Post edited by leroyjr1 on
  • Conradicles
    Conradicles Posts: 6,419
    edited January 2011
    Seems like a great price although I have not heard that particular model.
  • blueboxer
    blueboxer Posts: 621
    edited January 2011
    There is a parasound A51 on audioadvisor for a good price, I remember you were thinking about picking one up..
  • WilliamM2
    WilliamM2 Posts: 4,811
    edited January 2011
    I have been using a POA-2400 for over twenty years. I've also had Parasound, Adcom, NAD, and Rotel amps over the years. The POA-2400 is the only one that's still here...
    $125 is a steal, assuming it works. The only thing I never liked about it were the odd binding posts, which I finally took care of a couple of years ago.
    9.jpg 366.1K
    6.jpg 452.2K
  • leroyjr1
    edited January 2011
    blueboxer wrote: »
    Looking for the Halo A52. 125 watts per channel is more than enough for my efficient speakers.
  • leroyjr1
    edited January 2011
    WilliamM2 wrote: »
    Thanks for the info.
  • danz1906
    danz1906 Posts: 5,144
    edited January 2011
    leroyjr1 wrote: »
    Good price!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • xllr8
    xllr8 Posts: 23
    @WilliamM2 was there any cutting involved to make those fit? (the 5 way binding posts?)
  • WilliamM2
    xllr8 wrote: »
    If you look at the first pic, the original posts mount to a black plastic piece. I did not have to cut the chassis, bit I did have to drill holes in the plastic part larger, it removes with two screws.
    I think, it's been 19 years since I did that. I know I didn't have to cut any metal. I also don't know where to get those posts anymore.
  • PSOVLSK
    PSOVLSK Posts: 5,433
    Post a reply to a 15 year old thread asking a specific person a specific question and said person actually answers the question…the same day, no less. Impressive!
  • bcwsrt
    bcwsrt Posts: 2,646
    Good eye! Funny stuff! 😁
    I would not have remembered the answer to the question after 15 years, myself!
    Brian
