L600 mid driver equivalent?
Hello,
Does anyone know if the mid drivers from reserve series would match the legend series?
I called polk and was told nothing was available for the legend.
More knowledgeable good people, please help?
Thanks.
    pitdogg2 Posts: 27,921
    Call Polk and ask for Kim Jasper. Maybe Kim can check with the engineers and see if they have something for you.
    F1nut Posts: 52,406
    I believe the R500 mid-driver is the same 5.25" turbine driver as the L600.
    msg Posts: 10,650
    I gotta hear the story for why you need a mid driver for an L600.
    Does it involve kids and a box of sharp, stabby colored pencils?
  • Emlyn
    Emlyn Posts: 4,920
    If the L600s are not under warranty, could just buy a pair of used Reserve R100s and get two 5.25" drivers plus a pair of tweeters by cannibalizing. The drivers by themselves aren't cheap. Best to confirm with Polk that they are the same part numbers in both models first though. The 7 inch drivers won't be found in any other speaker.
    nooshinjohn Posts: 26,184
    It amazes me that Polk could provide drivers for 30 year-old SDA’s, but five minutes after the production line is shut down a new speakers they run out of parts. Glad I stocked up on my end before they shut down
  • tnxxnguyen
    tnxxnguyen Posts: 3
    msg wrote: »
    I just want to stock some spares. No one poked anything, yet.
  • Emlyn
    Emlyn Posts: 4,920
    Good idea because they are proprietary drivers in material and construction to Polk and the Legend line didn't seem to be around long enough that there are many speakers in the used market. If you can see the part number on the back of a 5.25" driver from your L600s that may help confirm with customer service that the same sized driver from a Reserve speaker will perfectly match.
  • tnxxnguyen
    tnxxnguyen Posts: 3
    Now I just need to make friends with someone who has the reserves to find out what the part number is.
    tnxxnguyen wrote: »
    Or call Polk like I suggested.
  • HzTweaker
    HzTweaker Posts: 1,137
    Between Polk's Monitor series and the SDAs there's probably close to 30 years of production.
    2ch rig: Speakers: LSi9s with VR3's Fortress mods Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
    Standby: Magnepan LRS w/Magna Riser stands
    mhardy6647 Posts: 35,562
    edited July 6
    Sounds like you haven't kept track of, e.g., the planned enforced obsolescence of AVRs in the past coupla decades. ;)
    It's all the rage in electronics. :(:#
    Interestingly, the EU has rules that require repair support of most electronic products for (if memory serves) five years after they're discontinued -- but that probably only formally applies to manufacturers' service centers.
    VR3 Posts: 29,763
    The way speaker manufactures operate is alot different than the way Polk and definitive ran.
    Polk, definitive and golden ear, I assume with sandy gross influence used the same drivers across many different models. This made them far easier to service and produce im sure.
    Polk the past twenty years has used different drivers across their lines and changed them with every line up change.
  • VintagePolkGuy
    The midrange driver for the L600 and L800 part # RD8681-1 are in route and we should see them by late July early August. They are specifically made for the L600 and L800 and there is no substitute.
    F1nut Posts: 52,406
    Kim, is that you?
  • Emlyn
    Emlyn Posts: 4,920
    Do the 5.25" drivers used in the Reserve speakers have a different part number with different specs?
    VR3 Posts: 29,763
    So going based off other designs, midrange drivers developed as a midrange only have a much tighter suspension than one built to handle bass
  • smglbrth
    smglbrth Posts: 1,506
    Ya, if i had bought some two years ago towards the end of the production run and had a warranty issue, being told "nothing was available" would down right tick me off, in a big way... Especially with a 5 year warranty...
