Calling all tube heads, calling all tube heads
VR3
VR3 Posts: 29,763
I found these inside of an old sonograph on the side of the road.
What have I found??
  • maxward
    maxward Posts: 1,744
    Perhaps an Antiques Roadshow appraiser will declare your find to be a National Treasure!
    pitdogg2 Posts: 27,921
    Old crusty tubes. You didn't find gold, if good you may have $70 worth of tubes. MAY, remember that.
    VR3 Posts: 29,763
    Not really concerned about the money aspect, just curious what they are.
    Figured I might be able to use some in my existing gear
    I see some of the markings but some are hard to make out
    VR3 Posts: 29,763
    I'm thinking the mullard and get are el84s
    The two smaller ones 12ax7?
    And the larger one is a rectifier tube?
    edited June 22
    Two el84/6bq5 one Mullard, one GE
    Two 12ax7 Tung-Sol
    Looks like an RCA rectifier 5Y3 maybe
    F1nut Posts: 52,406
    Calling Brock
  • invalid
    invalid Posts: 1,560
    VR3 wrote: »
    Probably a 5y3gt rectifier tube.
    heiney9 Posts: 25,724
    Calling Brock
    LOL.
    Hard to tell in the pic. I see an EL84 which today is used as a power tube, back then who knows
    The GE is a 6BQ5 same as the EL84
    12AX7 no writing, hard to tell. Maybe as Ivan said a Tungsol
    The other Tungsol looks smaller compared to the signal tube next to it. Need more info, but a signal tube
    The RCA is most likely a 6V6 because it's gray glass. Could be a rectifier as Ivan noted, but I think a 6V6 which today is a power tube used in many, many guitar amps from the 50's forward.
    That thing is not in stereo, I won't guess how the tubes were used since today the same tubes might be used differently
    But it appears you have (3) power tubes and (2) signal tubes.
    Any idea the year of the phonograph? Is it real of a reproduction?
    Is that all of the tubes? I don't see a rectifier tube. The EL84/6BQ5 can't be used as a rectifier and if the RCA is a 6V6 tube (pretty sure it is), it can't either.
    edited June 23
    Need to see the internal structure or the markings on the RCA to know if it's a 6V6 or rectifier like 5Y3. I can see markings obscured by dust. What does it say?
    RCA did make 5Y3 rectifiers with gray glass (smoked glass). Since I don't see any other obvious choice it could be a 5Y3 rectifier. Not a 6V6
    I can just make out a "5" in the stop sign on the RCA. It is indeed a 5Y3 rectifier.
    audioluvr Posts: 6,079
    That phonograph was not powered hence the crank on the side. They were probably bad tubes that someone threw in there for S&G's
    mhardy6647 Posts: 35,562
    edited June 23
    Actually, one could use pretty much any 'normal' vacuum tube (triode, tetrode, pentode, etc.) as a rectifier; just disconnect the grid or grids. B) Electrons flow from cathode to plate; that whole negative charge thing.
    Most repurposed multi-element tubes wouldn't be very useful for HV rectification in a DC power supply, but one could use 'em, e.g., as a detector for AM (or FM, for that matter).
    :D
    edited June 23
    audioluvr wrote: »
    I think the crank's a ruse. Note also the speaker driver in the horn.
    ahem. Also note the "modern" ;) multi-speed, automatic record changer.
  • tonyp063
    tonyp063 Posts: 1,157
    It's a Guild Grafanola. Built in the late '50's- early '60's & designed to look like an old Victorola player.
    PP mono with a pair of 6BQ5s. One 12AX7 as the AF amp & phase splitter for the output pair.
    5Y3 rectifier.
    The radio section used a 6BE6 for the first stage converter & a 6BA6 as the IF amp. The other 12AX7 was the pre-amp & AF amp with the tone controls between it's sections.
    I've got a schematic if you need it.
  • invalid
    @tonyp063 you are quite right, the rectifier tube is a 5y3, there is no way that can be mistaken for a 6v6 as it has 4 pins, two larger pins and two smaller pins.
  • invalid
    @mhardy6647 I can use 300b and 2a3 as a rectifier in my space tech lab super rectifier, but I prefer the 866a, 1616, or the 3b22.
  • newbie308
    newbie308 Posts: 849
    I think the RCA on the right is a 5Y4 GT full wave rectifier. If you zoom in, you can see the 5 (Dirt mark) and GT under that...
  • tonyp063
    It's a 5Y3GT
    Clipdat Posts: 13,107
    Ivan’s tube collection smells like feet.
    Clipdat wrote: »
    They shouldn't, I rub them on my dingus....
    Viking64 Posts: 7,836
    Clipdat wrote: »
    https://www.youtube.com/watch?v=8Tjy3uzhVwk
