You’re doing it wrong…
It's wrong because they didn't caulk around the siding, right?
They didn't label which one was for the backdoor doorbell. -
I'm glad you did at your house, but if you just had a button to push like a normal person, it would be a lot easier than flipping the switch up and down to make it go "ding-a-ling."
Brian -
Meanwhile poor Chester is turning circles trying to get to both doors....Cheap entertainment. -
Ivan's probably got one of those pull chains going up to a bell tower. The pull chain doesn't ring the bell, but instead looses a boot on a swing that kicks a hunchback, and he rings the bell.
Jesse's house is always dark, and there's always an eerie mist floating across the grounds, with a wolf that howls and people screams in the distance. This is in the daytime. Nicely kept grounds, though.
I disabled signatures. -
If you've noticed, I always hit the back doorbell first to throw him off!
How's he doing?!
Brian -
How's he doing?!
He's out of treats, you should come on by.......Don't tell the wife..... -
No, because the screws are on the same side. Ease of maintenance is critical.Expect that there will be bumps in the road. Choose to not let them rattle you.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc.
