You’re doing it wrong…
1118119120121122124»
    pitdogg2 Posts: 27,549
    msg wrote: »
    It's wrong because they didn't caulk around the siding, right?
    They didn't label which one was for the backdoor doorbell.
  • bcwsrt
    bcwsrt Posts: 2,582
    I'm glad you did at your house, but if you just had a button to push like a normal person, it would be a lot easier than flipping the switch up and down to make it go "ding-a-ling."
    Brian
    bcwsrt wrote: »
    Meanwhile poor Chester is turning circles trying to get to both doors....Cheap entertainment.
    msg Posts: 10,532
    Ivan's probably got one of those pull chains going up to a bell tower. The pull chain doesn't ring the bell, but instead looses a boot on a swing that kicks a hunchback, and he rings the bell.
    Jesse's house is always dark, and there's always an eerie mist floating across the grounds, with a wolf that howls and people screams in the distance. This is in the daytime. Nicely kept grounds, though.
  • bcwsrt
    bcwsrt Posts: 2,582
    bcwsrt wrote: »
    If you've noticed, I always hit the back doorbell first to throw him off!
    How's he doing?!
    Brian
    bcwsrt wrote: »
    bcwsrt wrote: »
    How's he doing?!
    He's out of treats, you should come on by.......Don't tell the wife.....
  • bcwsrt
    bcwsrt Posts: 2,582
    I thought we were friends!? 😳
    Brian
  • CGTIII
    CGTIII Posts: 1,259
    msg wrote: »
    No, because the screws are on the same side. Ease of maintenance is critical.
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
