Question on Wiim PS Audio DAC hookup
dromunds
dromunds Posts: 10,156
I have a PS Audio Gain Cell DAC that I purchased in the forum, and a buddy of mine is considering its purchase. He mostly streams, which I was going to get into but have not yet done so, and thus I’ve never even used the PS Audio DAC. He has a Wiim Pro Plus and a Marantz PM-10 integrated amp. The amp only has analog inputs if I remember correctly. Really nice amp. Not familiar with the Wiim or its outputs. My question is given his equipment, what would be the optimal way to hook up the PS Audio DAC for an audition? Thanks.
    pitdogg2 Posts: 27,488
    Don, it appears that DAC has both RCA and XLR inputs and outputs. Same with the Marantz. Why wouldn't that work?
  • Emlyn
    Emlyn Posts: 4,850
    I would go coaxial out from the Wiim streamer to the Gain Cell DAC then analog out from the DAC to the Marantz PM10.
    The power supply on the Wiim Pro Plus is a pretty cheap design. The Wiim Ultra is better.
  • rebelsoul
    rebelsoul Posts: 776
    Or you can go USB wiim out to dac in USB
    EndersShadow Posts: 17,732
    edited May 23
    Emlyn wrote: »
    A Ifi wall wart makes a difference as does a linear PSU, neither are that pricey.
    I run a WiiM Pro Plus with a Chinese linear PSU direct to my Pathos and it sounds quite good.
    Also like the EQ it has built in but I’m sure there are minor compromises in making but I’m ok with them.
    The WiiM has analog and digital outs, so I’d go with whatever digital out you prefer (spdif or coaxial) and then not use the EQ.
  • dromunds
    Thanks fellas!
  • dromunds
    I’ve never used XLR cables? How much audible difference is there compared to RCA cables?
  • Emlyn
    Emlyn Posts: 4,850
    In this application XLR vs RCA shouldn't make a difference if the cables are he same brand/quality.
  • Gardenstater
    Gardenstater Posts: 4,841
    Auditioned the WiiM Ultra combined with the Denafrips Enyo 15th when a buddy brought them by. I'd say it beat my SBT plus iFi nano idsd with more detail, especially cymbals. The Ultra has a USB out so I was able to use that. It didn't work with the EDO applet in the SBT. I should've tried a coaxial or toslink but didn't think of it.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    edited May 25
    dromunds wrote: »
    Ignore me
    Post edited by EndersShadow on
  • dromunds
    Enders, I sent you a PM regarding the Ifi and the Chinese linear PSU
    dromunds wrote: »
    I replied. Gotta love “Chynnna” products….. It’s a “WHUUUUGEEEEE” market
  • Upstatemax
    Upstatemax Posts: 2,836
    The Wiim Pro Plus is a great little streamer. I use one in my basement workroom and it was what I grabbed to get into music streaming. I've only really used it's analog outputs and for the price, it's really good. Very smooth sounding, but not exactly detailed. The Eversolo A8 I purchased to replace it in my 2ch system easily bested it.
    Dumping the digital signal off to a higher end DAC would be a great way to get into streaming without dumping a ton of $$$ into it.
    FYI, the Pro Plus is currently on sale on Amazon for $186.
  • Gardenstater
    I didn't want to say anything negative to my friend who brought the WiiM Ultra (he doesn't go on this forum lol) but he is stuck with the internal power supply whereas with the Pro Plus you can use a low noise one of your choice.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • dromunds
