Acoustic foam has been replaced
Costco had a tremendous sale on wood/felt acoustic panels. When my girlfriend asked me if that would work in my house, at first I thought she was wanting me to panel my walls......I thought, ugg no way, then took a closer look and thought, hey, this is good stuff.
At $30 a pop for a four panel box of 2'x2' panels, it was a no brainer. Here's what I have done so far....
Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
  • Gardenstater
    Gardenstater Posts: 4,960
    How thick is the felt? You could install those with a 1 in. gap between the wall and the felt if you want more sound absorption.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Geoff4rfc
    Geoff4rfc Posts: 3,059
    edited May 27
    The felt is 1/4" thick. The overall product is 1 3/4" thick. I'm certain you could shim it out to make a 1" gap if you want.
    The screws that come with it are 1.5" so you'd need longer screws for sure.
    These panels aren't very heavy. No need for wall anchors. Four screws per panel into the drywall and these babies are solid.......and are trimable. I took a box cutter to trim a slat off the bottom on one in order to clear a wall socket.
    They also come with end cap slats. A top and bottom end cap slat x 2 per box.....pretty nice deal.
  • Geoff4rfc
    Side wall is finally complete. Loving the new panels!!
