Robot lawn mowers
  • motorstereo
    motorstereo Posts: 2,391
    VR3 wrote: »
    I volunteer along with a few other parishioners to help mow our church cemetery. As I was mowing in the 90 degree heat yesterday I was wondering how a robot mower would work around the headstones? A set it and forget it robot mower with all those obstacles would be great I'm thinking.
    As long as the headstones were far enough apart for the mower to pass thru it would be fine. The success would be in the setup though, the initial mapping etc
    That's the problem; Some stones have enough room but lots don't and there's no real pattern to the rows. Then there's the markers, raised lots, trees, bushes, flags, flower pots and a few old stones that have tipped over. I use my 16" wide battery mower which is faster than my trimmer but it's still a chore and at 70yo I'm the youngest guy there. Perhaps a perfectly laid out and well manicured cemetery like Arlington would work.
    VR3 Posts: 29,623
    Gotcha, definite limitations for tight spaces and perimeters. With robot mowers you still have to weed eat and edge maybe every 2 weeks. So far I spend about ten minutes every 2 weeks
    gudnoyez Posts: 8,183
    Neighbor has one, instead sitting down admiring a fresh cut lawn and enjoying a cold one after mowing, he sits down enjoying a cold one while his yard is being mowed.
    treitz3 Posts: 20,203
    10 minutes, every two weeks to weedwhack? Geez, it takes me at least an hour, many times more. Lucky dog.
    VR3 Posts: 29,623
    The mower has a feature called edge sense or something another and it really captures the majority of the yard.
    The only thing it misses is directly beside the house and occasionally a patch of grass around an object but it does an extremely good job getting the bulk
    mhardy6647 Posts: 35,352
    I don't think a robot mower would like our yard very much.
    pitdogg2 Posts: 27,528
    edited May 23
    Goats would work much better for you.
    Viking64 Posts: 7,694
    Ivan! Please stay on topic!!!
    :p
    Goats are like robots -- bad robots.
    They do clear house though...
    Or yard, in this sense.
    F1nut Posts: 52,134
