Custom CRS+ Crossovers
xschop
Letting these point-to-point units go because I will build adapter plates to mount the Erse SBD Inductors to the factory boards in factory locations.
Had these running in SDA-converted 8TL's all last year.
5.75" x 9" x 1/2 solid Acacia wood. Jantzen inductors (got from member here) and MKP metallized polypropylene film capacitors and wire -wound resistors.
Solid Be-Cu copper binding posts and Neutriks. They have 13 gauge marine grade OFC wiring installed.
I will also throw in the factory 16mH sub-bass drive inductors....
$200 shipped US-48 and Alaska.
Just holler.
Just holler.
PM coming.2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: LSi9s with VR3's Fortress mods -
Guess I should add these work for the SDA-2B's as well.
Don't take experimental gene therapies from known eugenicists. -
My 2Bs are blade/blade as well.
Do these mount in the stock location? Looking at the pictures again i assume they don't. Which tweeter are they setup for?
You can mount them on adjacent wall with 1/2 spacers. They are set up for 194s, but if you solder in 5.8uf caps parallel to the resistor, 198's can be used.
I'll catch the shipping on these for members with 100 posts or better.
$175 Paypal friends/family or M.O.Don't take experimental gene therapies from known eugenicists.
