Custom CRS+ Crossovers
xschop
Letting these point-to-point units go because I will build adapter plates to mount the Erse SBD Inductors to the factory boards in factory locations.
Had these running in SDA-converted 8TL's all last year.
5.75" x 9" x 1/2 solid Acacia wood. Jantzen inductors (got from member here) and MKP metallized polypropylene film capacitors and wire -wound resistors.
Solid Be-Cu copper binding posts and Neutriks. They have 13 gauge marine grade OFC wiring installed.
I will also throw in the factory 16mH sub-bass drive inductors....
$200 shipped US-48 and Alaska.
Just holler.
Just holler.
PM coming.2ch rig: Speakers: LSi9s with VR3's Fortress mods Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: Magnepan LRS w/Magna Riser stands -
Guess I should add these work for the SDA-2B's as well.
Don't take experimental gene therapies from known eugenicists. -
My 2Bs are blade/blade as well.
Do these mount in the stock location? Looking at the pictures again i assume they don't. Which tweeter are they setup for?
You can mount them on adjacent wall with 1/2 spacers. They are set up for 194s, but if you solder in 5.8uf caps parallel to the resistor, 198's can be used.
I'll catch the shipping on these for members with 100 posts or better.
$175 Paypal friends/family or M.O.Don't take experimental gene therapies from known eugenicists. -
$150 shipped or they're going in storage for a future project.Don't take experimental gene therapies from known eugenicists.
Well that'll teach me to get busy and not look at the forums for awhile. Congrats on getting them sold.
Grabber70Mach wrote: »Well that'll teach me to get busy and not look at the forums for awhile. Congrats on getting them sold.
You would have needed to mount them in a different location if you are planning on adding the CRS+ baffle brace I posted.
These are going in some 2Bs.Don't take experimental gene therapies from known eugenicists. -
I'll check back in 7 years to be sure
#remindme- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Guess I should have added they work in SDA-10B's and SDA-8TL's too.
