Custom CRS+ Crossovers
xschop
xschop Posts: 5,932
Letting these point-to-point units go because I will build adapter plates to mount the Erse SBD Inductors to the factory boards in factory locations.
Had these running in SDA-converted 8TL's all last year.
5.75" x 9" x 1/2 solid Acacia wood. Jantzen inductors (got from member here) and MKP metallized polypropylene film capacitors and wire -wound resistors.
Solid Be-Cu copper binding posts and Neutriks. They have 13 gauge marine grade OFC wiring installed.
I will also throw in the factory 16mH sub-bass drive inductors....
$200 shipped US-48 and Alaska.
Just holler.
  • HzTweaker
    HzTweaker Posts: 1,137
    PM coming.
    2ch rig: Speakers: LSi9s with VR3's Fortress mods Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
    Standby: Magnepan LRS w/Magna Riser stands
    xschop Posts: 5,932
    Guess I should add these work for the SDA-2B's as well.
  • HzTweaker
    My 2Bs are blade/blade as well. :#
  • Grabber70Mach
    Grabber70Mach Posts: 79
    edited May 8
    Do these mount in the stock location? Looking at the pictures again i assume they don't. Which tweeter are they setup for?
    xschop Posts: 5,932
    edited May 8
    You can mount them on adjacent wall with 1/2 spacers. They are set up for 194s, but if you solder in 5.8uf caps parallel to the resistor, 198's can be used.
    xschop Posts: 5,932
    I'll catch the shipping on these for members with 100 posts or better.
    $175 Paypal friends/family or M.O.
    xschop Posts: 5,932
    $150 shipped or they're going in storage for a future project.
    xschop Posts: 5,932
    Sale pending.
    xschop Posts: 5,932
    Sold
  • Grabber70Mach
    edited June 10
    Well that'll teach me to get busy and not look at the forums for awhile. Congrats on getting them sold.
    xschop Posts: 5,932
    You would have needed to mount them in a different location if you are planning on adding the CRS+ baffle brace I posted.
    These are going in some 2Bs.
    VR3 Posts: 29,763
    I'll check back in 7 years to be sure
    #remindme
    xschop Posts: 5,932
    edited June 10
    Guess I should have added they work in SDA-10B's and SDA-8TL's too. B)
