Custom CRS+ Crossovers
xschop
Letting these point-to-point units go because I will build adapter plates to mount the Erse SBD Inductors to the factory boards in factory locations.
Had these running in SDA-converted 8TL's all last year.
5.75" x 9" x 1/2 solid Acacia wood. Jantzen inductors (got from member here) and MKP metallized polypropylene film capacitors and wire -wound resistors.
Solid Be-Cu copper binding posts and Neutriks. They have 13 gauge marine grade OFC wiring installed.
I will also throw in the factory 16mH sub-bass drive inductors....
$200 shipped US-48 and Alaska.
Just holler.
Just holler.
PM coming.2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: LSi9s with VR3's Fortress mods -
Guess I should add these work for the SDA-2B's as well.
Don't take experimental gene therapies from known eugenicists. -
My 2Bs are blade/blade as well.
Do these mount in the stock location? Looking at the pictures again i assume they don't. Which tweeter are they setup for?
You can mount them on adjacent wall with 1/2 spacers. They are set up for 194s, but if you solder in 5.8uf caps parallel to the resistor, 198's can be used.
