Vintage Monitor and SDA Speaker Deals
1254255256257258260»
    xschop Posts: 5,466
    Worth experimenting on.
    What MWs did they come with?
    pitdogg2 Posts: 27,423
    edited April 29
    xschop wrote: »
    MW6600 or MW6501
    Mine was the SDA1 signature and they came with MW6600 in all spots except the dimensional spot, it was MW6501. Later models came with all MW6501. I'm fairly sure the MW6501 and MW6600 were identical in specs. I ran one speaker with all MW6600 and the other with MW6501, I could tell zero difference.
    Boy, Edwin from Polk Customer service sure fouled up the response. He gave info on the SDA1b, which they are NOT! Polk CS sure has fallen way down the mountain.
    Toolfan66 Posts: 18,226
    xschop wrote: »
    Not for $1600 :#
    I must admit, the electric socket for the interconnect is genius ;)
    xschop Posts: 5,466
    Ive looked for that model before just to make a tweeter plate to go center of all the mids and have a listen.
    edited April 29
    xschop wrote: »
    The original SDA1 with ports also had boxes inside the cabinet built around the top drivers. There was papers in the vintage speaker section that walked you through the removal of the boxes and plugging the ports to turn the SDA1 into the SDA1a. Your best bet to do what you would like is to look for the SDA1a. There would be a ton less work involved and a LOT less glue to scrap out. My .02
    xschop Posts: 5,466
    Good info.
    Id just sawhole the center and drop in a round bezel using the stereo tweeter circuit.
    If I liked what I hear, then pretty er up.
  • agingboomer
    agingboomer Posts: 411
    Polk Audio SDA Compact System Speakers Pair Left Right
    Currently listed at shopgoodwill.com starting bid $49.95
    https://shopgoodwill.com/item/263067527
    local pickup only in San Diego
    I wouldn't touch them with a ten foot pole. Those are trash.
    xschop Posts: 5,466
    Sell the 6511's and double your investment lol.
    xschop wrote: »
    1. If they had mw6511 you're dreaming that they will be good.
    2. They came with 2 mw6503
    3. You should know this.
    xschop Posts: 5,466
    Can't tell what iteration they are. Sell the 6503's and quadruple yer duckets then.
    The cabs look a tad better than the first set I stumbled upon lol.
    Blade/blade interconnect CRS
