Vintage Bogen LS20 Refurb
I have a pair of very vintage Bogen LS20 speakers from my dad's collection that I want to refurb. Before you ask, "why bother?", this is primarily for wifey, who loves the vintage look, especially the grill cloth fabric. The cabinets are in good shape, along with being quite solid at 3/4" thick. The turquoise thread accent is really nice (and better in person), along with the metal strips that frame the grills.
I agree with her on the looks, but not the sound...even under the best conditions. In one of the speakers, the woofer voice coil is rubbing, and the paper tweeter cone has a tear. So, I'm considering replacement drivers, and a new two-way crossover. The original woofers are 8", and have DC resistance of 3.5 ohms. The tweeters are 3.5", and are at 8.5 ohms. Cabinet volume is about 0.81 cubic feet. These are sealed/acoustic suspension speakers.
So, without going crazy, I'm considering these woofers: https://www.simplyspeakers.com/replacement-speaker-woofer-w-208-4.html
And these tweeters: https://www.simplyspeakers.com/replacement-speaker-tweeter-t-145.html I would have to enlarge the cut-out in the speaker baffle very slightly, but that wouldn't be a problem.
Lastly, I would likely go with a pre-fabricated crossover like this: https://www.simplyspeakers.com/speaker-crossover-2-way-a-1302.html But, I need help on the crossover frequency options. The woofers have a range of 45-7000 Hz, and the tweeters go from 3.5kHz to 20kHz.
Thanks in advance for any advice!
    billbillw Posts: 8,173
    edited April 17
    I'd think hard about the blending of an 8" woofer and a small dome tweeter. I would maybe just look at an 8" full range? That would eliminate crossover worries. Cost might be higher and you have to seal the tweeter opening or design it into a tuned port? Probably all more design headache than you are looking for.
    If you stick with a 2-way, maybe try to imitate the Mission 700 series driver and crossover design? I don't think you want 12bB sloped crossover on a 2-way with such a gap in driver size.
    xschop Posts: 5,790
    edited April 18
    I'd suggest the Dayton DC28F and a 1.5-2K Hz crossover. With a very low Fs, it's sure to blend with any 8" woofer much better.
    The factory crossover sticker on those show 1100 HZ crossover.
    Love the vintage resto-mods. Looks like real aluminum strips/trim in the baffles?
  • jdjohn
    jdjohn Posts: 3,437
    Thanks for the responses. Lots to consider with both drivers and crossover. Here's a pic of the original crossover:
    Looks like an air-coil inductor, and not sure about the capacitor. The L-pad variable resistor is clearly corroded, so need to evaluate that further.
    For now, I'm pulling some drivers from my dad's 'inventory', for consideration.
  • jdjohn
    jdjohn Posts: 3,437
    I have a line on some Philips AD 8080/M4 full-range drivers with the 'whizzer' dual-cone design. I'd likely 'tune' the tweeter cutouts to create an aperiodic box. These drivers are 4 ohm, but I have some beefy SS amps/receivers I could try. Probably overkill, but don't want to skimp with that low impedance. I don't have any tube amps.
  • jdjohn
    jdjohn Posts: 3,437
    After digging through my Dad's collection, I found a pair of Philips AD 0160/T8 dome tweeters with good continuity, and then ordered some modern 8" woofers from Parts Express. Enlarging the baffle cut-outs for the vintage Philips tweeters was a challenge (free-handing with a router), but luckily they are hidden behind the grill cloth. The new woofers were basically drop-in replacements.
    The resulting speakers sound very nice. I think they will more-than serve their purpose in a future small living space for kitchen and entertainment, with a vintage flair.
