I'm getting SDA SRS 1.2s soon
Im getting these in 8 days and had a few questions and am getting different answers. Does anyone in here have experience with these?
    pitdogg2 Posts: 27,372
    Most of us!
    What are your concerns?
  • BsSDAs
    BsSDAs Posts: 16
    Yes hello in 7 days I get them and I can't wait . I don't know lots about them but I got for awesome price. I had a Denon AVR-X7200W but I sold because I was told there would b issues so I bought a Adcom GTP-500 & GFA-555ll. But anyways I was told now that my room is not big enough I'm putting n my bedroom. It's
    148" width
    142" depth
    95.5" height
    I have a TV mounted to wall and I can't drill anymore holes so anyways I was told they need to b even? When I figured it out they would then both sit 9" from side wall and 9" away from rear wall. And I was told that's not good. Also the guy I got Adcom from had a few pairs and he said he liked them better with out cable but everything that I have read says not to use without it? Ive never had any speakers with so many rules. They were owned by a good friends father who recently passed. So I got opportunity to buy. Any advice is appreciated!!!
    I pretty excited I'm going from a/d/s/ Sat6 bookshelf to the Polks.
  • hoosier21
    hoosier21 Posts: 4,422
    Stuff them in that room and have a ball.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • BsSDAs
    BsSDAs Posts: 16
    Also I have a Klipsch SPL -120 but I'm being told I won't need a sub. I find that hard to believe. I've had Polk Monitor 11T before and that also had passive well that had a 8 and 10 passive radiator if I remember correctly and they made bass from mids also. How much bass will they make? Lots of what I'm being told this from is guy who owns a lesser model of SDA. Im jus curious l. I'm really not a vintage fan so much but I have owned a few but never some that wouldn't run on receiver. I'm a M&K Sound fan.
  • BsSDAs
    BsSDAs Posts: 16
    Sorry one more thing I've seen SDA SRS 1.2 & SDA SRS 1.2TL what does that mean? What's difference? My first thought was transmission line but thought it's a passive radiator so I doubt that.
    edited April 13
    BsSDAs wrote: »
    Different tweeters. 1.2 came with SL2000 tweeters. The 1.2tl came with the SL3000 tri-laminate (TL) tweeters.
    You will not find out what the SDA is all about in that small room set-up. Closer to the wall more better bass, farther out from the wall less bass. They make REAL GOOD bass, do not let those little 6.5" drivers fool you.
  • JCL
    JCL Posts: 171
    I believe it’s the use of the tri-laminate tweeter.
    L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
    F1nut Posts: 52,026
    A 12 x 12 x 8 foot room is a square box, about the worst for any speaker especially SDA speakers.
  • BsSDAs
    BsSDAs Posts: 16
    Dam that is what I have been being told. I have friend helping me get them to my room so I don't even know about moving them after either. No body commented on the guy telling me he likes them better without the cable?
  • BsSDAs
    BsSDAs Posts: 16
    Thank you for the info !!! So there is upgrades for these does anyone know what they are and price range? I read about tweeter upgrade but that is so they won't b as bright I like bright
    F1nut Posts: 52,026
    Without the SDA cable connected you are missing everything SDA speakers are about.
    Use the search feature, there's an almost unlimited amount of info here on all things SDA.
    If you like bright, ear bleeding sound look at Klipsch.
    edited April 13
    Well that guy is not very bright. That guy probably had them set up wrong, they may of had them toed in like regular speakers which is a no no with SDA.
    In a different room where they can breathe they will create a huge stage. A good set of speakers set up correctly will absolutely disappear in the room. By that I mean the sound no longer comes from the speakers themselves, it comes from a huge wall of sound where you think the wall behind them is making the sound. The singer is locked in the middle, the other instruments are exactly where you are expecting them to be. Very few speakers can do this.
  • hoosier21
    Stuff them in that room and have an amazing time with them.
    Later you will need help with the why what when how of those speakers.
  • Emlyn
    Emlyn Posts: 4,838
    Those speakers in that room will make it sound like sitting inside the music. B)
  • BsSDAs
    BsSDAs Posts: 16
    Emlyn didn't I read somewhere that you had some SDAs that were close to wall? Was room you had them in close to my size room? Did you later put them in bigger room? If so what was difference?
  • Emlyn
    Emlyn Posts: 4,838
    I had a pair of the original SDA-SRS in a room that was around 11 x 11 feet for a while. They were fun to listen to in that space but the only furniture in there with them was a two-seater sofa up against the wall opposite the speakers. Stereo imaging was fine but they overloaded the room with bass reinforcement if they were played at too high a volume and had a small soundstage compared to what they were capable of. They performed as designed only when I moved them to a suitably sized room in a different house that was large enough to let them breathe.
    nooshinjohn Posts: 26,003
    I had a pair of them in a 19x15 space, and they were too much for the room. I downsized to a pair of Legend L800...
  • BsSDAs
    BsSDAs Posts: 16
    edited April 15
    Interesting very interesting. They belonged to a good friend's dad who passed he definitely doesn't want me selling them. He let me have for $500 and he knows his **** about audio he said I probably won't b searching anymore. I change equipment every so often. I think I have like 5 days to go till I get. I'm pretty excited
    (I jus added this)
    He tells me they are mint like new
  • BsSDAs
    BsSDAs Posts: 16
    I especially appreciate the info on the small rooms thanks guys
    You stole them !
    Toolfan66 Posts: 18,198
    edited April 15
    Do you have pictures?
    Where are you located?
  • skipshot12
    skipshot12 Posts: 2,096
    Question: Does not using the SDA cable change the frequency response of the SDA's?
  • BsSDAs
    BsSDAs Posts: 16
    Is that possible?
  • BsSDAs
    BsSDAs Posts: 16
    I've never seen cable would it b hard to make?
    BsSDAs wrote: »
    No it is not had to make, I'd make sure you get the original at any cost. Without the cable the SDA function will not work. The 8 speakers in each cabinet will still have the sub-bass drive active and the stereo drive active. The 4 SDA speakers in each cabinet will only have the sub-bass drive network active.
  • BsSDAs
    BsSDAs Posts: 16
    I really didn't understand that last comment. And thank all of you for the info! I did a search like someone had suggested and I thought I saw that these are 4 ohms? That is first time I'm hearing this.
  • BsSDAs
    BsSDAs Posts: 16
    Oh and I'm getting original cable with it positively. My friend who's selling or sold them to me is very knowledgeable in audio equipment I'm VERY fortunate to have met him. He has a pair of speakers that remind me of the SDA STS 1.2 at least in physical size. He has the Mirage M1si. I know completely different bipolar I mostly meant size. At least as far as from what I have read. I absolutely loved the sound of the Mirage I think they are the BEST speakers I've ever heard. Today is the 17th and I get them on 20th I can't wait. I feel like kid waiting for Christmas! I'm also very appreciative to you all here everyone has been informative and polite. A while back I joined a Facebook group for vintage Infinity speakers and I had joined because I had just bought a pair of Infinity Overture llls and wow was that a rude bunch of people! I like to experience different brands and models of speakers . I liked the Overtures but my biggest complaint was the highs I like lots of highs and they had one small tweeter. While I had them I bought a pair of M&K SX-4 which had 2 huge tweeters mounted on top of speakers and I fell in love with the highs so much better so then I bought a pair of M&K S100Bs which had 3 tweeters. So I had 5 tweeters on front left and right I ran both pair for fronts on A/B setup. I love lots of highs and with both of those up front I had plenty the motor for tweeter looked like it belonged to a mid or small sub. I'll post a pic in case some you haven't seen. I was told to expect even more highs from these !bw4mr0cpudjk.jpg
    F1nut Posts: 52,026
    The tweeters in the SDA SRS, SDA SRS 1.2 and SDA SRS 1.2TL speakers are a progressive point source. Only one of the tweeters plays the full high frequency range. The other 3 play different limited high frequency ranges.
    Your assumption that more tweeters
    means even more highs is rather naive.
    What is your obsession with a lot of highs, do you have diminished high frequency hearing?
