Request for Polk DSW-PRO 660wi Schematic Diagram
tipo
Hello everyone,
I am currently troubleshooting a Polk DSW-PRO 660wi subwoofer that has lost power. Upon inspection, I found several burnt power resistors and degraded capacitors near the voltage regulation stage.
I am looking for the schematic diagram or the service manual to identify the exact values of the damaged components.
Any help or guidance would be greatly appreciated. Thank you in advance!
Schematics sent...
Thx a lot!
Is it the same diagram for the DSW600?
The outer label says DSW660, but the internal board says DSW600 (200W).
To the best of my information I believe they are the same. There might be some differences in EQ from model to model but the overall topology is the same.
K tysm
yrwelkm
