Need a speakon connector that can accommodate 13.5mm speaker cable housing.
I have the discontinued NL2FX speakon connectors, I bought a new furutech cable for my sda2a speakers but the blue retention collar doesn't fit over the cable housing. Is there a larger one, and are the newer versions any better, as the ones I have don't seem to have a very robust connection to the conductors.
    VR3 Posts: 29,740
    Do you have pictures of your issue
  • invalid
    invalid Posts: 1,559
    I'll take some pictures later today.
  • invalid
    edited March 16
    The blue collar is the problem, it doesn't fit over the cable housing, the other picture is the conductor termination that doesn't look like much.
    VR3 Posts: 29,740
    edited March 16
    I recommend removing the outer jacket and going to heat shrink and a collar[, you can see in this photo.
    I've never had any issues with the set screws not grabbing the wire. Very secure
  • Conradicles
    Conradicles Posts: 6,431
    edited March 16
    Whatever kind VR3 used on my SDA's are pretty impressive.
    Edit: That picture is not my SDA crossovers for the record!
    VR3 Posts: 29,740
    Yeah the new neutrik connectors with the green barrels are a huge improvement over the old blue ones.
    F1nut Posts: 52,407
    edited March 16
    Use the best one. It takes up to a 16mm cable as is. With a little custom work one can fit almost double that.
    https://www.neutrik.com/en/product/nlt4fxx-bag
  • invalid
    That will work, looks like it's way better constructed than the NL2FX I have.
    F1nut Posts: 52,407
    I was a bit off with my, "almost double" comment, but its been a long time since I did one. That connector will take up to a 22mm OD cable with a little modification.
    VR3 Posts: 29,740
    The nl2 is a smaller connector since it's meant for 2 conductors
  • Unknown
  • invalid
    VR3 wrote: »
    I only have 2 conductors, I guess that Neutrik didn't figure for this higher end cable.
  • Unknown
  • invalid
    Can you drill out the end to accommodate the larger diameter?
    I thought about doing that, but I just ordered the newer bigger better ones instead.
