SDA-2B Studio, ideas for upgrading the pedestal?
I haven't been following the Vintage Speaker section much since I sold my pair of SDA-1C in 2010. I recently acquired a pair of 2B Studio and I'm thinking about ways to improve on the factory pedestal which is too narrow and isn't tapped for spikes. Has anyone else tackled this before with success? I searched here and with Google and couldn't find anyone who had posted about this.
I was thinking of fabricating a 1" thick board to almost match the outer dimensions on the base the cabinet. Maybe it would be 1/8" smaller overall? Then painted black with something durable like Granotone speaker paint. The corners would be tapped in a standard thread for spikes/decoupling feet and I would attach it with some type of elastomeric adhesive and wood screws.
I suppose another option would be to just remove the pedestal and tap the speaker cabinets directly, but I don't want to loose height and I don't want really long spikes.
    xschop Posts: 5,794
    Outriggers?
    billbillw Posts: 8,191
    edited March 3
    xschop wrote: »
    Outriggers?
    I'm afraid I'd stub my toes :D Something to think about though. Thanks for the idea.
    F1nut Posts: 52,377
    xschop Posts: 5,794
    Scratch all that.
    You need a set of Larry's spikes. >:)
    edited March 3
    What am I looking at Jesse? You removed the fiber board box and just installed those large spikes? Are those "Larry's Spikes?" I'm afraid to ask what those would cost to make these days.
    nooshinjohn Posts: 26,137
    Send them off to the crew at “Pimp my Ride”, or as he is known here, XS Chop…
    VR3 Posts: 29,731
    Yeah I usually just install spikes
    xschop Posts: 5,794
    Just throw some Duelands at it 'til it sounds better.
    F1nut Posts: 52,377
    Not from Larry. Not sure where I bought those. I looked around, but didn't see them anywhere. However, I did see these...https://edensoundaudio.com/shop/solid-brass-spike-extra-large/
    IIRC, the base is 1.5" tall, so those brass spikes would retain the proper height.
    VR3 wrote: »
    I guess my thinking was that the original cabinet material isn't the strongest. I've seen lots of spikes that get bumped and the threaded insert just destroys the surrounding wood/fiber. I guess I'll do some looking around for spikes that can get flush, which would lessen the torque on the cabinet wood if it were bumped.
    VR3 Posts: 29,731
    I haven't experienced that but I also use power grab on the threads during install
    Those aren't a bad price. Parts express has some that are also 1.5" tall, but they are built in 3 or 4 pieces with the adjustable tip. I prefer the 1 piece solid cones.
  • invalid
    invalid Posts: 1,559
    Spikes worked great on mine, but I got lucky and bought them about 10 minutes from my house for $32 from meniscus audio, but the owner retired a few years ago.
    pitdogg2 Posts: 27,875
    invalid wrote: »
    I did a ton of business with Menicus Audio, miss them and Ogden audio greatly.
  • invalid
    I really miss Meniscus audio, I could just walk in there and buy stuff. The owner Mark never charged extra for close tolerance capacitors, he even unwound an inductor and measured it until it was the correct value I needed.
  • invalid
    Better picture of the spikes I used, they are about the same size as the original pedestal.
  • invalid
    billbillw wrote: »
    VR3 wrote: »
    The holes for the spike inserts can be hardened believe in or not with super glue, just use it around the hole and then use power grab on the inserts. This works well, I got the idea from my foosball tournament days, the edges of the goals on tornado foosball tables would chip out from time to time and if you used super glue around the edges it would soak in and harden the MDF.
    I guess I know the best approach now, and it should be easier than fabricating a new base board.
    edited March 6
    Brass cones ordered today along with some new fabric for the tired grills on the 2B. Also getting some miscellaneous DIY cable stuff to re-do my Nanotec Golden Strada speaker cables that have been boxed up for 4 years. I'm going to put those back into the mix and compare with the Monolith speaker cable that I've been using and a set of Canare 4S11G cables that I'm also about to DIY build. The winner will take prime stage and the others will be distributed to secondary systems...or sold.
    And just as I'm typing this, I realize I did the bonehead move of only ordering 4 cones instead of 8. SMH. Time to call and see if they can change the order to include another 4 before shipping.
    edited March 22
    A quick question for vintage experts. Is this the factory method used around 1990 for attaching the fabric or has someone already redone these in the past? I recall my RTA11T used glue for the fabric.
    Edit: after taking out most of the staples, I don't see any glue residue. I guess this was factory.
  • agingboomer
    agingboomer Posts: 632
    Just checked my SDA 2B Studios (bought in 1988). The fabric was glued on. No staples. The uneven cuts in yours would suggest they were redone.
    billbillw wrote: »
    Yes, my sda2a was the same way.
    35 years of dirt 😬
    Done with the first one.
  • Conradicles
    Conradicles Posts: 6,424
    Looks fantastic! Good job.
  • VSAT88
    VSAT88 Posts: 1,383
    Same exact thing I did...
  • agfrost
    agfrost Posts: 2,493
    billbillw wrote: »
    A little late to the party, but my 2B Studios (originally blade-blade):
    Jay
    It has been a long time. These were on the back burner, but I finally installed brass cones (black chrome coated) on my 2B.
    These gone...
    These to replace...
    That's about the end to the upgrades for these, but except maybe Trey's felt pads...
    F1nut Posts: 52,377
    Be sure to seal the old holes.
    I sealed the old holes and the new holes. These spikes needed a full penetration for the threaded insert and post.
