SDA-2B Studio, ideas for upgrading the pedestal?
billbillw
I haven't been following the Vintage Speaker section much since I sold my pair of SDA-1C in 2010. I recently acquired a pair of 2B Studio and I'm thinking about ways to improve on the factory pedestal which is too narrow and isn't tapped for spikes. Has anyone else tackled this before with success? I searched here and with Google and couldn't find anyone who had posted about this.
I was thinking of fabricating a 1" thick board to almost match the outer dimensions on the base the cabinet. Maybe it would be 1/8" smaller overall? Then painted black with something durable like Granotone speaker paint. The corners would be tapped in a standard thread for spikes/decoupling feet and I would attach it with some type of elastomeric adhesive and wood screws.
I suppose another option would be to just remove the pedestal and tap the speaker cabinets directly, but I don't want to loose height and I don't want really long spikes.
Outriggers?
I'm afraid I'd stub my toes
Something to think about though. Thanks for the idea. See profile for rigs. Nothing else here. -
President of Club Polk -
Scratch all that.
You need a set of Larry's spikes.
Don't take experimental gene therapies from known eugenicists. -
What am I looking at Jesse? You removed the fiber board box and just installed those large spikes? Are those "Larry's Spikes?" I'm afraid to ask what those would cost to make these days.See profile for rigs. Nothing else here.
Send them off to the crew at “Pimp my Ride”, or as he is known here, XS Chop…The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Yeah I usually just install spikes- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
nooshinjohn wrote: »Send them off to the crew at “Pimp my Ride”, or as he is known here, XS Chop…
Just throw some Duelands at it 'til it sounds better.Don't take experimental gene therapies from known eugenicists. -
Not from Larry. Not sure where I bought those. I looked around, but didn't see them anywhere. However, I did see these...https://edensoundaudio.com/shop/solid-brass-spike-extra-large/
IIRC, the base is 1.5" tall, so those brass spikes would retain the proper height.Political Correctness'.........defined
I guess my thinking was that the original cabinet material isn't the strongest. I've seen lots of spikes that get bumped and the threaded insert just destroys the surrounding wood/fiber. I guess I'll do some looking around for spikes that can get flush, which would lessen the torque on the cabinet wood if it were bumped.See profile for rigs. Nothing else here. -
I haven't experienced that but I also use power grab on the threads during install- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Those aren't a bad price. Parts express has some that are also 1.5" tall, but they are built in 3 or 4 pieces with the adjustable tip. I prefer the 1 piece solid cones.See profile for rigs. Nothing else here. -
Spikes worked great on mine, but I got lucky and bought them about 10 minutes from my house for $32 from meniscus audio, but the owner retired a few years ago. -
I did a ton of business with Menicus Audio, miss them and Ogden audio greatly.Spikes worked great on mine, but I got lucky and bought them about 10 minutes from my house for $32 from meniscus audio, but the owner retired a few years ago.
I really miss Meniscus audio, I could just walk in there and buy stuff. The owner Mark never charged extra for close tolerance capacitors, he even unwound an inductor and measured it until it was the correct value I needed.
Better picture of the spikes I used, they are about the same size as the original pedestal. -
The holes for the spike inserts can be hardened believe in or not with super glue, just use it around the hole and then use power grab on the inserts. This works well, I got the idea from my foosball tournament days, the edges of the goals on tornado foosball tables would chip out from time to time and if you used super glue around the edges it would soak in and harden the MDF. -
I guess I know the best approach now, and it should be easier than fabricating a new base board.See profile for rigs. Nothing else here.
Brass cones ordered today along with some new fabric for the tired grills on the 2B. Also getting some miscellaneous DIY cable stuff to re-do my Nanotec Golden Strada speaker cables that have been boxed up for 4 years. I'm going to put those back into the mix and compare with the Monolith speaker cable that I've been using and a set of Canare 4S11G cables that I'm also about to DIY build. The winner will take prime stage and the others will be distributed to secondary systems...or sold.
And just as I'm typing this, I realize I did the bonehead move of only ordering 4 cones instead of 8. SMH. Time to call and see if they can change the order to include another 4 before shipping.
A quick question for vintage experts. Is this the factory method used around 1990 for attaching the fabric or has someone already redone these in the past? I recall my RTA11T used glue for the fabric.
Edit: after taking out most of the staples, I don't see any glue residue. I guess this was factory.See profile for rigs. Nothing else here. -
Just checked my SDA 2B Studios (bought in 1988). The fabric was glued on. No staples. The uneven cuts in yours would suggest they were redone.The arc of the moral universe is long, but it bends towards justice.—Martin Luther King Jr.
Yes, my sda2a was the same way. -
35 years of dirt 😬
Done with the first one.
Looks fantastic! Good job.
Same exact thing I did... -
A little late to the party, but my 2B Studios (originally blade-blade):
Jay
It has been a long time. These were on the back burner, but I finally installed brass cones (black chrome coated) on my 2B.
These gone...
These to replace...
That's about the end to the upgrades for these, but except maybe Trey's felt pads...
Be sure to seal the old holes.Political Correctness'.........defined
I sealed the old holes and the new holes. These spikes needed a full penetration for the threaded insert and post.See profile for rigs. Nothing else here.
