New to me 10B
Saw these listed on CL the next town over. Auditioned in a really dark old trailer house, hooked up to an extremely tired-sounding low end 80s receiver & CD player.
Dirty and dusty, but the cabinets/vinyl were nearly mint. The half-dead amp didn't really give any indication of sound quality, all drivers appeared to work and there was no woofer rub. I have a set of 7Bs I've owned and loved since the 80s, so I pulled the trigger.
Connected them to the Dynaco, and they sound pretty good! The crossovers appear to be untouched, have stickers from '85 and '86.
My order of crossover rebuild parts arrives tomorrow, looking forward to seeing how much improvement that brings.
Dynaco PAS3/ST35
Pioneer SA-5200/SA-500/PL-514
Sony TA-1120A
Dual 1249
Polk 7B/10B
  • Gardenstater
    Gardenstater Posts: 4,921
    edited November 2025
    I think they will sound better if you can pull them out into the room a bit (experiment with how much) and put them on some solid stands with mass to them to raise the acoustic center up closer to your ear height and to decouple from the wooden floor somewhat, especially if it is a suspended floor above another room and not on solid concrete. It is never good for imaging to have stuff between the speakers. Don't forget to replace those SL2000 with RD0194 when your budget allows. Order them from Polk and ask for the forum discount.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • MarkC568
    The mailman brought my crossover rebuild parts today, so I spent the early evening rebuilding those. Back together now, the new caps need to burn in a bit, but these already sound less constrained.
    I've pulled them out another foot or so, which does seem to improve imaging. A set of stands in definitely on the menu. I think I have enough oak scraps to build a set without needing to buy much more.
    This room's in the basement, so there's concrete right underneath that laminate.
    New tweeters on the list for sure too. I wouldn't say these are shrill, but they are a bit much.
    Do you have to call Polk to order the 194s, or are they somewhere on their site?
    Thanks for the guidance!
    Dynaco PAS3/ST35
    Sony TA-1120A
    Dual 1249
    Polk 7B/10B
    F1nut Posts: 52,381
    Call Polk. You want the RD0194-1, that's a zero.
  • Al_Swearengen
    Hey…nice job on those stands. I’ve got some 7Bs as well. I’m looking forward to your impressions on how they compare with the 10s once you get those new tweets in!
    FKA: anton.chigurh (see profile page)
    Toolfan66 Posts: 18,412
    Very nice job on the stands!!
    Any pics of the crossovers?
  • MarkC568
    No new tweeters yet, December budget is kind of wrapped up in Xmas things. Will probably order those in January.
    Here's a shot of one of the rebuilt crossovers. New caps and resistors came from Parts Express. The green resistors are pretty long, but they have long copper leads, so everything fit nicely.
    Dynaco PAS3/ST35
    Sony TA-1120A
    Dual 1249
    Polk 7B/10B
    F1nut Posts: 52,381
    I'm curious, why didn't you upgrade the most important cap, the yellow mylar?
  • MarkC568
    I don't typically replace film caps, since they are generally good long-term, unlike electrolytics.
    But I'm willing to replace them if there's a benefit.
    Dynaco PAS3/ST35
    Sony TA-1120A
    Dual 1249
    Polk 7B/10B
    F1nut Posts: 52,381
    It's a crappy mylar, easily bettered. Stick a Jantzen Superior Z or Clarity CSA in there. You can thank me later
  • Gardenstater
    edited December 2025
    Both of those 12uF mylars were in series with the tweeter but you only replaced one with the Audyn. Not all film caps are created equal. Polypropylenes are considered to be better than Mylar. They have lower dissipation factor DF.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 52,381
    Huh?
    xschop Posts: 5,796
    Maybe he likes the sound.
    F1nut Posts: 52,381
    There's only one mylar on a 10B crossover.
    xschop Posts: 5,796
    Depends on what was in Polk's part bin that day at Gallagher Mansion.
  • Gardenstater
    What tightwads! That electrolytic is in series with the tweeter also, even if it is part of the contour network. If I was replacing only one of them I would've done what OP did as well as that electrolytic probably has more than 10% DF at this point in time and mylar is probably still around 1%.
    But I wouldn't have done only one.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,796
    Polk was being economical. As evidenced by their Procurement Specialist...
    https://www.youtube.com/watch?v=z-q29hbEP04
  • MarkC568
    Thank you for the recommendation. I'll likely do this after I replace the tweeters.
    Dynaco PAS3/ST35
    Sony TA-1120A
    Dual 1249
    Polk 7B/10B
  • SeleniumFalcon
    Nice vintage system you got there!
  • MarkC568
    Thanks! It's been a fun project to get it assembled over the last couple of years.
    Dynaco PAS3/ST35
    Sony TA-1120A
    Dual 1249
    Polk 7B/10B
  • MarkC568
    New tweeter day! These arrived from Polk sooner than I would have expected.
    Excited to get these installed tonight.
    Dynaco PAS3/ST35
    Sony TA-1120A
    Dual 1249
    Polk 7B/10B
    pitdogg2 Posts: 27,881
    A lot of us glued a stainless steel washer on the back side to keep the bezel from deforming as badly when tightening down to the box. It can deform enough without them to cause a buzz from deformation of the plastic bezel pressing down on the voice coil.
  • HzTweaker
    HzTweaker Posts: 1,121
    2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
    F1nut Posts: 52,381
    edited February 25
    #10 stainless steel washer.
    Rob's tweeter bezels are excellent! You can have them anodized black or leave them natural. Whatever you do, don't polish the heck out them...looks like yuck.
  • MarkC568
    Just happened to have some stainless washers, so I dropped these in.
    I completed the rebuild of the Sony 1120A a few weeks back, so it's been the main amplifier since then. This setup sounds really good.
    So far I'd say the RD0 tweets still have plenty of high end, just at a more balanced level compared to the SL2000.
    Dynaco PAS3/ST35
    Sony TA-1120A
    Dual 1249
    Polk 7B/10B
    xschop Posts: 5,796
  • VSAT88
    VSAT88 Posts: 1,383
    edited March 3
    After listening to the RD0-198 tweeter I am firmly NOT in the RD0-194 camp. I really cant even listen to those 194's. Not after I know now what I am missing. They are calm sounding for sure. Balanced as you suggest. However there is simply too much sonic information that is lost in my opinion with that 194. I liked mine when I had them but no more. Thanks anyhow. I would rather run a SL-2000 and finer gear upstream. Your system is magnificent!
