New to me Model 10
Hey Polk Audio freaks, new member, just scored a set of Model 10s, sounded and looked amazing at demo. Got them home and it seems one of the cabinets is vibrating/ resonates at a higher volume. Removed radiator and inspecting cabinet but can't find anything. Any suggestions from the experts. Love to figure it out, thanks y'all...Here's a few pics...tf357cwno0ft.jpg
    Tony M Posts: 11,679
    edited February 5
    Is the white wire possibly hitting the passive radiator?
    Maybe a suspension spider is loose on a midbass.
    Congrats on getting an AWESOME set of Polk Audio CLASSICS. B)
  • TLOC
    TLOC Posts: 10
    Tony M wrote: »
    Thank you Tony, hard to explain but it seems more like the cabinet itself...Tony L
    edited February 6
    Does it vibrate with that passive being out?
    OH, by the way, I started loving Polk Audio speakers after I bought a set of Monitor 10s just like yours. I then bought a set on eBay before the shipping cost went up. I still own one set of the Moniitor 10s, and will when I die.
    audioluvr Posts: 5,982
    Check to make sure you don't have a screw loose. On your speakers I mean.
  • Geoff4rfc
    Geoff4rfc Posts: 2,927
    Welcome to Club Polk. I hope you're able to resolve the vibration issue. These guys can be very helpful!! :)
    Set up: 11.2 HT + 2ch
  • TLOC
    TLOC Posts: 10
    Well, I kept troubleshooting the vibration and literally can see the side panel is free of the rear panel down nearly the whole seam. WOW, with a lot of bass it's so obvious! Now, don't want to screw through the cabinet and it appears the rear panel is too thin to screw some small right angel brackets. Thinking of Titebond 3 Ultimate wood glue and some clamps, thoughts from the gallery?
    Great.
    Can you spread the panel away enough to get some wood glue into the joint and then clamp it back together?
  • TLOC
    TLOC Posts: 10
    Sure, would it be a disgrace to install small right angel brackets inside the cabinet and glue as well? May 3-4, HD has 1"x1" right angel brackets in black with screws. I checked this morning and both panels are 3/4"(.75) +/- thick...thoughts???
    I wouldn't use L brackets.
    You could glue the joint back together and let it set. You could then glue a long corner moulding to reinforce the original joint. A 1"x 1" X how long that joint is. That joint would then be pretty solid.
  • TLOC
    TLOC Posts: 10
    Titebond 3 Ultimate on the inside seam and Titebond Quick & Thick on the rear seam, 6 clamps... :|
    pitdogg2 Posts: 27,203
    edited February 12
    After the glue up, I would do all the seams with Power grab heavy duty and push into both panels. Not only will it help with sealing up for no air leaks, it will also bond all the panels together for a more solid box. Many of us have done the same.
    https://www.lowes.com/pd/LOCTITE-Power-Grab-Heavy-Duty-White-Latex-Interior-Exterior-Construction-Adhesive-Actual-Net-Contents-9-fl-oz/1001059990?
  • TLOC
    TLOC Posts: 10
    So after the repair speaker sounds really good, new problem OTHER speaker tweeter fuse blowing after I put correct 1A fuse in. They're were 2A installed, go figure! It played for a few mins then blew. Questions, how do I know the tweeters are original peerless? Also, is this now a crossover issue? Third, do I start with replacing like for like modern caps or go whole new board? So far Ive replaced a set of binding posts on one, cutted and glued the other cabinet and cut, desoldered all driver connections and replaced with new gold plated female blade style...good grief...
  • TLOC
    TLOC Posts: 10
    And suggestions or recommendations would be much obliged...Thanks y'all!
  • TLOC
    TLOC Posts: 10
    Installed the 2A back in, nothing, cut power twist fuse in clips,power on, nothing, cut power, cussed awhile. Back on have tweeter momentarily...🤬🤬🤬
  • TLOC
    TLOC Posts: 10
    I suppose I'll go get some wind therapy on the Road Glide then work in the yard awhile til I hear from you fellas...✌️
  • bcwsrt
    bcwsrt Posts: 2,475
    They'll be along sooner or later. Shiny side up!
    Brian
    The wires to the fuse block are known to corrode. Many folks remove the fuse block in its entirety. I'd start looking there first. The caps and resistors are way past due to be replaced.
