Time to replace the old Yamaha avr
    billbillw Posts: 7,654
    edited February 5
    muncybob wrote: »
    It occurred to me that she should upgrade her lampcord speaker wires while doing this. She needs a total of 20' non terminated. Anybody ever satisfied with some from Amazon, or would a trip to Best Buy do the same?
    I was going to recommend the wire I used last time I built a set of cables, but it seems like Monoprice discontinued the wire.
    It was a pretty good deal at $39 for a 25' spool. Now they just sell terminated versions and they are advertising them as 14AWG and not 12AWG like the stuff I bought.
    https://www.amazon.com/Monolith-Multi-Strand-Conductors-Speaker-Wire/dp/B07Q8WDF1K?
    At this point, I think the Canare 4S11 (or 4S11G) is a better recommendation, especially if you want un-terminated. In fact, I may just buy a length and do another set since I have exactly 8 Audioquest silver coated copper spades left from a bulk purchase about 18 years ago.
  • muncybob
    muncybob Posts: 3,255
    "Does this amp have PFFB? I am guessing no." Actually the WiiM Ultra does have it.
    Yep, my name really is Bob.
    edited 10:56AM
    You might also consider WiiM's earlier WiiM Amp or WiiM Amp Pro, which are priced a fair bit lower ($300-$380), but those models might have all she needs. They are about half as powerful as the Ultra, and don't have the fancy touchscreen, but both were well reviewed a few years ago.
    https://www.wiimhome.com/wiimamp/overview
    https://www.amazon.com/dp/B0DFPJ91ZX?th=1
    Question is, will 60wpc into 8ohm or 120w into 4ohm be enough power? I think the difference between the Amp and Amp Pro is an improved DAC in the Amp Pro along with better cooling and the addition of PFFB in the Pro.
    Post edited by billbillw at
