Corner Repair Help
Any ideas on how to fix this? Just picked up a pair of Polk Monitor 7s and didn't catch this until I got home with them.
Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Amplifiers: ]Ashly FTX 2001 III, Dynaco ST-70, DIY F6
Pre: Adcom GFP 750, Aikido Tube Pre
    xschop Posts: 5,734
    edited January 17
    Welcome to vintage Polk.
    I'd use Liquid Nails Pro. Let it set up a few days, then wood putty and sand back the corners. The vinyl wrap is toast.
  • bored184
    bored184 Posts: 333
    edited January 17
    xschop wrote: »
    Fill in the gap or use clamps to close the gap then putty?
    These definitely will need some love but the price was cheap. They will get redone and TL modded.
    xschop Posts: 5,734
    Shoot the goo from inside, ensuring it protrudes all the way through to outside. Then clamp and dry 36 hrs. While you're in there do all the inner corners with a bead.
    I'd highly suggest adding a 1"dowel or two front to back between MW and PR.
    The 7Cs are incredible fully modded.
    F1nut Posts: 52,282
    Good luck closing that gap up.
    nooshinjohn Posts: 26,102
    This... before glueing anything, you need to understand why the entire seam opened up. It needs to be thoroughly cleaned up to get the surfaces to mate properly and then it can be glued. If the material has any water damage, it might be easier to make new cabinets to the same internal volume out of MDF.
    Tony M Posts: 11,958
    edited January 18
    That cabinet might be salvageable at a low cost.
    I've seen a lot of those swollen cabinets in my time. Water damage. :s
    BUT, you can make it look better in a sense.
    Get a can of this putty. 14.00 a can. It goes a long way. One might fill what you need.
    MIX some, pour some. REPEAT until the canyon are full to the rim. Use a toothpick or a sharp shard of something to force putty down into the crevices of the canyons. ;)
    Maybe put tape over that vinyl wrap to protect it from over-spill.
    Then sand flat.
    Then paint it black
    F1nut Posts: 52,282
    ^That's about as ghetto as it gets^
    mhardy6647 Posts: 35,504
    To say nothing of the black paint requirement. That stuff is hard to find, as we all know.
    xschop Posts: 5,734
    When the cabs are that bad, there'always truck bedliner. B)
  • motorstereo
    motorstereo Posts: 2,412
    Glue, clamps, brad nails and veneer in that order.
  • maxward
    maxward Posts: 1,738
    As a cabinet maker in a former life, this could be a “fun” project, but jeez, how much do you value your time?
    edited January 18
    I highly doubt there's clamping that will close that swollen joint.
    When you have swollen wood, you have to go to the hood. :D
  • bcwsrt
    bcwsrt Posts: 2,639
    maxward wrote: »
    Hey, his handle is “bored.”
    Brian
  • maxward
    ^^^Good point!
  • bored184
    bored184 Posts: 333
    I've tried clamping and as its already been pointed out the gap did not close. It doesn't look swollen from moisture but its not budging.
    Can I take a heat gun and dismantle the cabinet? Im wondering if I can jusy replace the bottom panel.
    xschop Posts: 5,734
    Time to get medieval on dem cabs.
  • slow_polk7
    I would empty the cabinet completely, then use a Ryoba (japanese saw w/o spine) or some sort of flush cut saw to cut through the entire length of the joint.
    You should then be able to either clamp it back together w/o gaps, or insert a shim the entire length of the gap to completely seal the cabinet.
    F1nut Posts: 52,282
    bored184 wrote: »
    The cabinet is particleboard. When that material breaks it basically turns into jagged/crumbled pieces.
    You can try the suggested saw idea, but don't use a good Japanese saw as the material will likely break some teeth off.
  • bored184
    bored184 Posts: 333
    They arent marked series 2 but they have the SL-2500 tweeter and their crossover matches the m7s.rev2 crossover.
