1193194196198199204
    mhardy6647 Posts: 35,153
    Viking64 Posts: 7,592
    And people thought I was crazy to teach my dog to Schitt all over the house. B)
    pitdogg2 Posts: 27,169
    Viking64 wrote: »
    Maybe next time try a Yorkshire Terrier instead of the Mastiff....
    txcoastal1 Posts: 13,514
    Got me some diesel today…$2.49 😊
  • aprazer402
    aprazer402 Posts: 3,400
    edited January 10
    In the past I've stopped at a Goodwill near me maybe once a month. I used to go more years ago, when you would still find some good media. I bought a couple media items in Dec. for 59¢ each.
    On Friday, I stopped for a few minutes as I was at the post office next door, I saw two mint Bartok RCA Red Seal records. I had them in my arm ready to head out. Then I noticed their new media prices sign. I wasn't paying $3.99 each for something that I could easily do without. I didn't buy anything. Records were 59¢ in December.
    nooshinjohn Posts: 25,954
    Viking64 wrote: »
    Thought it was a St. Bernard...
  • skipshot12
    skipshot12 Posts: 2,061
    edited January 11
    txcoastal1 wrote: »
    Geez... I really hate these prices on gas!
    Can we please go back to Biden-Nomics when everything was really awesome.
    We just went under 2 a gallon in Laramie too.
    Speaking of, what ever happened to that kinjit, flex, fix, kix person?
    Can't remember the name... sorry bout that but, couldn't resist.
  • Geoff4rfc
    Geoff4rfc Posts: 2,901
    txcoastal1 wrote: »
    I love where you shop!!! I've always preferred my beavers to be ethanol free!!
    Say "hey" to Buc-ee for me
    Set up: 11.2 HT + 2ch
    Cables: Mogami AES from CDP to DAC - AQ McKenzie XLR from DAC to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 707 power conditioner.
    billbillw Posts: 7,688
    You would probably never guess this is Dame Helen Mirren. She was a wild child in her 20s.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,797
    (Just South of Atlanta) Lake Spivey, GA 1970. ZZ Top opens for Ike & Tina Turner Revue.
    Harry / Marietta GA
    Toolfan66 wrote: »
    What in tarnation is that critter? Is that a speaker?
    xschop Posts: 5,283
    edited January 12
    TL= Transmission Line or T*rd Line?
  • jdjohn
    jdjohn Posts: 3,373
    Toolfan66 wrote: »
    I've heard of open-baffle, but that's NO baffle.
  • jdjohn
    jdjohn Posts: 3,373
    xschop wrote: »
    Why?
    Many of my most trusted mechanics over the years have insisted it does not do an engine good. My vehicles have gotten better fuel mileage with 100% gas.
    I believe the fuel lines, in particular, can be damaged by the more corrosive nature of ethanol. It also retains moisture more readily than petroleum fuel, so that's no beuno as well...for obvious reasons.
    SCompRacer Posts: 9,121
    edited January 12
    I see plumbing code violations, no occupancy permit granted. :D Schedule 80 pvc is required for TL.
    The builder of that TL was/is, doubtless, flushed with pride vis-a-vis their accomplishment.
    B)
    xschop Posts: 5,283
    The enclosure build savings should have allowed for Duelund or Mundorf caps.
    xschop Posts: 5,283
    jdjohn wrote: »
    xschop wrote: »
    Why?
    Ethanol is hygroscopic by nature, but at 10% conc. in petrol it won't absorb much H2O. The problem with leaving in engines stagnant over long periods is it contributes to the formation of organic acids that eat at everything, especially pot alloy carbeurator bowls.
  • motorstereo
    motorstereo Posts: 2,359
    jdjohn wrote: »
    xschop wrote: »
    Why?
    A lot of the fellows on the snowblower forum I'm a member of also get uptight about ethanol gas for whatever reason. In my case I buy 50 gallons of my small engine gas once every 18 months-2 years. It's 87 octane and probably has ethanol; I'm not sure as I don't check but it is the cheapest grade of gas I can get. I treat each 5 gallon can with an ounce to a gallon of seafoam or walmart's version which is about half the price as soon as I get home. All my small engines (boat, lawnmower, pressure washer, generator, snowblower) start right up settle into a normal idle and I've never once drained a carb or had any issues in the 15-20 years I've been doing this. I did have the bowl off the blower last year to change the main jet and there's no corrosion in there after 11 years. Nope; I don't buy the ethanol gas is bad nonsense.
    F1nut Posts: 51,887
    My snowblower's engine warranty would have been void if it needed engine service under warranty and was found to have used ethanol infused gasoline.
    The last several small engine tools I bought all stated 90+ octane 100% gas was preferred in the owners manual.
    If not 100% gas no more than 10% ethanol. There's a lot of states that they're starting to sell 15% or higher ethanol content gas.
    Also around here the 85% ethanol gas, could be 85% ethanol or 85% gas or any combination between those two numbers. There is only a 20 cent difference between 85% ethanol and 10% ethanol gas. It used to be like 40 or 50 cents difference.
    treitz3 Posts: 20,048
    Ethanol IMO should be illegal. Buying gas should only involve pure gasoline.
    xschop Posts: 5,283
    treitz3 wrote: »
    At least no BT-corn ethanol lol. Farmers gotta get paid by subsidies and Monsanto too.
    audioluvr Posts: 5,974
    I love ethanol! Especially with pomegranate and Ginger Ale. As for fuel preservation, just use Startron fuel treatment. That elimates the negative effects of alcohol in pump gas.
  • motorstereo
    I had to check my Honda blower manual. Seems I'm fine as long it's 10% ethanol.
    What was this thread about again? Three pages full of gas and nary a picture in sight.
  • skipshot12
    Speaking of gas preservatives Project farm on youtube has a really good comparison.
    https://youtu.be/OHXYWxMkhog
