hifihaven.org
And people thought I was crazy to teach my dog to Schitt all over the house.
Maybe next time try a Yorkshire Terrier instead of the Mastiff.... -
Got me some diesel today…$2.49 😊
In the past I've stopped at a Goodwill near me maybe once a month. I used to go more years ago, when you would still find some good media. I bought a couple media items in Dec. for 59¢ each.
On Friday, I stopped for a few minutes as I was at the post office next door, I saw two mint Bartok RCA Red Seal records. I had them in my arm ready to head out. Then I noticed their new media prices sign. I wasn't paying $3.99 each for something that I could easily do without. I didn't buy anything. Records were 59¢ in December. -
Thought it was a St. Bernard...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
txcoastal1 wrote: »Got me some diesel today…$2.49 😊
Geez... I really hate these prices on gas!
Can we please go back to Biden-Nomics when everything was really awesome.
We just went under 2 a gallon in Laramie too.
Speaking of, what ever happened to that kinjit, flex, fix, kix person?
Can't remember the name... sorry bout that but, couldn't resist. -
I love where you shop!!! I've always preferred my beavers to be ethanol free!!
Say "hey" to Buc-ee for me -
You would probably never guess this is Dame Helen Mirren. She was a wild child in her 20s.
(Just South of Atlanta) Lake Spivey, GA 1970. ZZ Top opens for Ike & Tina Turner Revue."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
TL= Transmission Line or T*rd Line?Don't take experimental gene therapies from known eugenicists.
I believe the fuel lines, in particular, can be damaged by the more corrosive nature of ethanol. It also retains moisture more readily than petroleum fuel, so that's no beuno as well...for obvious reasons."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I see plumbing code violations, no occupancy permit granted.
Schedule 80 pvc is required for TL. Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
The builder of that TL was/is, doubtless, flushed with pride vis-a-vis their accomplishment.
The enclosure build savings should have allowed for Duelund or Mundorf caps.Don't take experimental gene therapies from known eugenicists.
Ethanol is hygroscopic by nature, but at 10% conc. in petrol it won't absorb much H2O. The problem with leaving in engines stagnant over long periods is it contributes to the formation of organic acids that eat at everything, especially pot alloy carbeurator bowls.Don't take experimental gene therapies from known eugenicists. -
A lot of the fellows on the snowblower forum I'm a member of also get uptight about ethanol gas for whatever reason. In my case I buy 50 gallons of my small engine gas once every 18 months-2 years. It's 87 octane and probably has ethanol; I'm not sure as I don't check but it is the cheapest grade of gas I can get. I treat each 5 gallon can with an ounce to a gallon of seafoam or walmart's version which is about half the price as soon as I get home. All my small engines (boat, lawnmower, pressure washer, generator, snowblower) start right up settle into a normal idle and I've never once drained a carb or had any issues in the 15-20 years I've been doing this. I did have the bowl off the blower last year to change the main jet and there's no corrosion in there after 11 years. Nope; I don't buy the ethanol gas is bad nonsense. -
My snowblower's engine warranty would have been void if it needed engine service under warranty and was found to have used ethanol infused gasoline.Political Correctness'.........defined
President of Club Polk -
The last several small engine tools I bought all stated 90+ octane 100% gas was preferred in the owners manual.
If not 100% gas no more than 10% ethanol. There's a lot of states that they're starting to sell 15% or higher ethanol content gas.
Also around here the 85% ethanol gas, could be 85% ethanol or 85% gas or any combination between those two numbers. There is only a 20 cent difference between 85% ethanol and 10% ethanol gas. It used to be like 40 or 50 cents difference. -
Ethanol IMO should be illegal. Buying gas should only involve pure gasoline.
At least no BT-corn ethanol lol. Farmers gotta get paid by subsidies and Monsanto too.Don't take experimental gene therapies from known eugenicists. -
I love ethanol! Especially with pomegranate and Ginger Ale. As for fuel preservation, just use Startron fuel treatment. That elimates the negative effects of alcohol in pump gas.Gustard X26 Pro DAC
I had to check my Honda blower manual. Seems I'm fine as long it's 10% ethanol.
What was this thread about again? Three pages full of gas and nary a picture in sight.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Speaking of gas preservatives Project farm on youtube has a really good comparison.
https://youtu.be/OHXYWxMkhog -
― Aleksandr Solzhenitsyn
