New arm suggestions needed
No, it’s not an Ed Gein thread. (“He always had a hand to lend.”). I’m looking for an arm for a Thorens TD-150 and wondering if anyone has any suggestions. Also, wondering if anyone has an arm sitting in the proverbial closet they’d be willing to part with. The table currently has a wooden arm that was made by a guy in California until he passed a few years back but it has issues and it’s time to move on. Thanks. Don
  • skipshot12
    skipshot12 Posts: 2,156
    Have zero knowledge with the Thorens's and of no help there.
    However, I do have an extra arm I was using with my Denon DP. An SME Series III.
    The III requires medium-high compliance cartridges if interested.
    Skip
  • newbie308
    SME arms work very well with Thorens turntables FWIW
  • SeleniumFalcon
    You'll want to choose a replacement tonearm that is similar in weight to the original in order to maintain the correct suspension tuning.
  • maxward
    maxward Posts: 1,742
    Vinyl Nirvana might give you some ideas. SME and Rega arms seem to be the most popular.
  • dromunds
    dromunds Posts: 10,174
    PM coming, Skip. Thorens used SME arms. I had a few back in the day on other tables, including a Denon DP-75. Wish I never sold that table.
  • skipshot12
    Roger
    audioluvr Posts: 6,079
    No?
    SCompRacer Posts: 9,399
    edited January 1
    Ken brings up a valid point regarding tonearm weight. I ran into that on a Linn LP12. Cranking up the tension on the arm side suspension with a heavier arm caused more issues that cancelled the better arms contributions.
    I'm sure you're aware a new arm with different center of pivot to spindle specs will require a new arm board.
    I've seen folks with a Micro Seiki MA505 MKII on the TD-150. That was a great arm. I had one on a dual arm Nottingham Space Deck. I had both straight and curved arms for it. Another arm that qualified for the wish I never sold that...
  • dromunds
    Yes, I’ve made several arm boards, including for the arm currently on the Thorens. Thanks for the advice on the Micro Seiki and also reiterating tonearm weight concerns. Don
    edited January 1
    For folks that like to run multiple cartridges, while the MA505 straight arms did not have a removable headshell, the arms were easily swapped via thumb screw. The straight pipes had fixed headshell while the curved arms had removable headshells.
    I had another arm that was held on by thumbscrew, a Moerch DP6 (Dual Pivot). Moerch offered both 9" and 12" arms for it. They also had four choices of effective mass arms identified by a color dot to easily match cartridge compliance. The DP6 isn't a real heavy arm. It's a fantastic performing arm but I think pricing keeps it off a suggested arm list.
    My patented on the fly VTA adjuster for the DP6. :D
    Duh, I had a MKIII.
  • skipshot12
    Agree.
    Also, the SME Series III had additional weights to be able to use with the Low Compliance cartridges.
    But, by adding those weights.... I always wondered if that changed anything with the original design of the tonearm's capabilities of proper compliance?
