Got my 5B's out of storage.......
heiney9
heiney9 Posts: 25,672
edited December 2025 in Speakers
Forgot how good these can sound. Mine have had the full refurb (except the gluing of the magnets and basket dynamat)
An older refurb with Solens on the low end and Clarity caps on the high end, RD0 tweets. Larrys rings and Mortite
Vocals really soar on these. Bass is a bit shy until you get some volume. They seem just a bit more sensitive than the R200's.
Running a 10wpc Pass DIY ACA amp and Pass DIY Korg Nutube B1 pre. Listening to some vintage Christmas music.
It's early, but I think the vocals are a bit better on the 5B's. But they could just be calling more attention because of the lack of lower mid bass and bass at my level of listening.
Why have these been in storage so long? Vocal presence and clarity is superb.
Current trio of office rig speakers
Merry Christmas Eve
  • Gardenstater
    Now that you hauled them out, you have to do the Dynamat and magnet gluing. When I did the Dynamat I definitely heard more natural conga drums, for example.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    Perhaps.
    I switched back to the R200's and while the 5B's had great vocal presence. So did the R200's and everything else the R200's was better in spades. The 5B's are kind of shouty compared to the R200's. There is no contest between the Vifa tweet and RD0. The Vifa is worlds smoother, more open and more natural sounding and less strident.
    Everytime I re-listen to the 5B's I come back to one conclusion. They have no bass or rather don't have the bass punch I remember from owning my 1st pair in the 90's. I should take them apart and see if there is an issue.
    Merry Christmas
    xschop Posts: 5,796
    You have a few unmitigated issues with those 5B's. If those are 194 RDO's then the plastic bezel is a detriment. Dynamat is a must for the baskets and the foam frame mod rids the "shouty-ness".
    The bass extension is pretty good for their size cabinets and they are great in smaller rooms, but the 7's fixed that issue with their bass extension and output compared to 5Bs.
    Merry Christmas everyone.
    I'll take your comments into consideration. But I'm talking about how they used to sound after the upgrades vs. now. They sound off comparing oranges to oranges.
  • Gardenstater
    Gardenstater Posts: 4,921
    Maybe check and make sure the polyfill didn't slide down to around the passive radiator instead of up behind the midwoofer and tweeter. Sometimes when the VC starts to rub occasionally it can affect the bass only too.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • skipshot12
    skipshot12 Posts: 2,142
    Hey xs,
    Regarding the RD0 tweeters... is the plastic bezels being a detriment just with the 5B's or does that include my Gen 3 SDA SRS's?
    Is that something I should consider upgrading too?
    Skip
    pitdogg2 Posts: 27,883
    skipshot12 wrote: »
    Hey xs,
    Skip
    Unless Rob makes more of the aluminium tweeter bezels, you're out of luck.
    xschop Posts: 5,796
    skipshot12 wrote: »
    Hey xs,
    Skip
    That includes ANY factory RD0 bezel. The lost resolution and increased resonance applies to any monitor or SDA with them.
  • skipshot12
    "Unless Rob makes more of the aluminium tweeter bezels, you're out of luck."
    Dang it!
    Always a $1 short.
