My 12 step program has gone awry
    SCompRacer Posts: 9,112
    Here is an older thread from this forum discussing tube shields.
    https://forum.polkaudio.com/discussion/177718/tube-shields/p1
  • invalid
    invalid Posts: 1,455
    I really doubt that a power tube in a preamp is going to get near as hot as it would in a power amplifier output stage.
  • ALL212
    ALL212 Posts: 1,656
    What matters here is not how hot the tubes get but extending the life of, what are now expensive, tubes by removing what heat they do produce from the surface of the glass.
    I’d prefer to never have to purchase another tube. IERC covers may be the way to do so and if I can’t get those I’ll find others that are similar.
    Aaron
    Enabler Extraordinaire
  • ALL212
    ALL212 Posts: 1,656
    Emlyn wrote: »
    I found the Pearl Tube Coolers (not sure if that's the brand above) to deaden the sound on a preamp but didn't have a negative effect on the sound from a 6550 tubed power amp. They were inexpensive enough to try out, at Parts Connexion recommendation, and stash away if not being used.
    Yes, those are Pearls.
    I like IERC better - especially those with the internal “fingers” instead of plates.
    Aaron
  • Emlyn
    Emlyn Posts: 4,703
    Yes, Chris Johnson threw in a bunch for free to try out when I sent a Sonic Frontiers preamp in for upgrade. They were too much of a good thing on that 12 tube preamp but I did end up using some dampeners on the most important signal tubes to good effect.
  • ALL212
    ALL212 Posts: 1,656
    The “Lefty” is back in production. Lefty as it’s the left side of the listening room.
    Odyssey Audio Kismet stereo amp.
    Bottlehead Moreplay pre
    Bottlehead C4 headphone amp
    Twisted Pear DAC hiding in the repurposed Yamaha receiver chassis
    Nakamichi tape deck
    Polk LSi 7’s with massive upgrades
    Aaron
  • maxward
    maxward Posts: 1,691
    Cool dragon, too.
  • ALL212
    ALL212 Posts: 1,656
    edited January 11
    maxward wrote: »
    Cool dragon, too.
    Enhances the musicality by 5%
    He’s just shy of 50 years old.
    Aaron
  • maxward
    If he’s made of glass, he’s had a long lucky life. My wife collects dragons and plays around with glass.
    xschop Posts: 5,154
    Nice. I have one of those HP mini's with 1TB worth flac files. Great little Music server.
  • ALL212
    ALL212 Posts: 1,656
    That mini is one of a few Roon bridges in place.
    Aaron
