Last Posted in 2009… Now I’m Stuffing Two 18s into My Attic Return – Help Me Not Blow Up the House
Hey everyone,
My last post here was way back in 2009 — It's great to see the forum still going strong!
Life got in the way for a while — bought a house, got married, the usual ups and downs — but I’m finally jumping back into the audio hobby. Loving good music again and putting together a clean, minimalist 5.1 setup in the main listening room, plus piping tunes downstairs for drinks with my wife, the dog, and friends around the firepit.
Current Main 5.1 Setup (2nd floor TV/listening room)
Denon AVR-X4800H (arriving today — early birthday/Christmas gift!)
Oppo BDP-83 universal player
L/R: Polk Monitor 8T (silver coil)
Center: Polk CS10 (just won a Monitor 5 on eBay that’ll be here soon — planning to swap it in)
Surrounds: Polk Monitor 5jr (silver coil)
Sub: ancient powered Yamaha from a relative’s old HTiB… it’s embarrassing
Which brings me to the subwoofer plan…
The house is a 1950s expanded Cape. The right wall of the listening room backs onto an unfinished, uninsulated attic. There’s an old 14" × 25" A/C return cutout in that wall (bottom of the opening is 50" off the floor, top at 75"). Seems like the perfect spot for an infinite baffle sub!
IB Sub Plan
(2) Dayton Audio UMII18-22 Ultimax II 18" drivers
Small sealed enclosure ~10" × 24" × 24" built from ¾" MDO plywood, mounted between the studs
Cover with a grille to match the room
Powered by a Behringer NX3000D (with DSP)
Basically turning that giant unused return into a huge manifold straight into the attic — should have basically unlimited airspace back there.
Any thoughts, gotchas, or “you’re gonna hate this” warnings before I start cutting and ordering drivers?
Thanks!
    VR3 Posts: 29,496
    As someone who has ran an infinite baffle for a decade.. You need to find a way to mount this thing to something other than the wall. It needs to be floating in the wall cut out and not directly attached. It needs to be secured in your attic.
    That wall will vibrate like crazy!
    Otherwise best theater/gaming bass bar none.
    Terrible for music
    VR3 Posts: 29,496
    Also I would reach out to fi audio in regards to their Ib drivers, they will perform much better than the Ultimax
  • Jstas
    Jstas Posts: 14,991
    I would add that if you don't want excessive amounts of bass bleeding over into the other rooms that share walls/floors/ceilings with that attic space then invest in some rock wool insulation to minimize sound transfer.
    Expert Moron Extraordinaire
  • maxward
    maxward Posts: 1,710
    If my memory serves me correctly, one of the reviewers in the early days of the absolute sound magazine (PHD, Philip H. Donnlicot(?)) had a couple of 18-inch woofers installed into his floor. Might want to check out some of the back issues from the 1980s.
  • I'm planning a Dual-Opposed Manifold - force cancelling... to supposedly handle the vibration, and using the Ultimax II because I want the slightly stiffer suspension for transient response. Love the feedback here! Partially inspired by "Eric's Home Theater"
    https://sites.google.com/bucknell.edu/ericshometheater/erics-home-theater/infinite-baffle-subwoofer?authuser=0
  • Jstas
    Jstas Posts: 14,991
    Infinite baffle subs are pretty cool but they can be tricky. You don't have much wiggle room on being able to fudge a baffle/enclosure design for them. You have to be dead on with your dimensions otherwise you might end up with a one note wonder that hits a resonance sweet spot that just shouts at that one frequency point while the rest of the response range gets attenuated.
    One thing I used to do with infinite baffle or "free air" installations in cars, especially ones with the "dual opposed manifold" design like you are planning is I made every wire the same length. Depending on your mounting location and the distance from the signal source to the amp and from the amp to speaker, you have the chance that signal lead length could create a cancelation effect because the distance traveled creates a time alignment issue. Especially in a house where a signal lead or speaker lead can be a significant distance.
    In a tandem baffle situation where all the drivers are facing the same way, it's not such a big deal. But when you have to oppose them and wire them to compliment each other, being out of sync even slightly can cause audible anomalies and unwanted resonances from distortion due to misalignment of the drivers.
    With signal wires like RCA leads or optical cables, it's not a big deal as they are typically congruent in length for the channels used if it's not a mono channel. But speaker leads, unless you purchase them already made and terminated, you really need to pay attention to your lengths and terminations on the ends.
    Just food for thought, especially given how finicky an infinite baffle design can be.
    VR3 Posts: 29,496
    edited December 2025
    Mine are mounted like yours
    Your entire house will move, isolated from the wall will be Good move
    EndersShadow Posts: 17,713
    VR3 wrote: »
    Has it really been 10 years already?
    VR3 Posts: 29,496
    Almost, 2018... Time flies
    Best subwoofer I've ever owned for movies!
    Seriously though, for music it's pretty slow but it's good for like around the house. Dedicated 2 channel? Like a tank chasing a ferrari
  • Jstas
    Jstas Posts: 14,991
    Man, now I want to go build a subwoofer enclosure
  • Well, that confirms it. I'll give it a try and report back here - just hope it doesn't take 9 years! Thank you all for your expertise and experiences. Now I just need to figure out how to sneak into the house!
  • Jstas
    Jstas Posts: 14,991
    I find that sneaking around on your tip toes helps a lot
  • omfgppc
    omfgppc Posts: 13
    Still some work todo, but it is progressing...
    It wouldn't fit in the old AC return grille hole because the roof interfered with the drivers... durr... It's in a more manageable spot now.
    Some box finishing to do, wiring, make an EPDM rubber boot to connect to the port in the wall, etc. Should be operational Jan 4th.
  • daddyjt
    daddyjt Posts: 3,120
    Let the “rattle-hunt” begin;-)
    Looks good…!
    ― Aleksandr Solzhenitsyn
  • skipshot12
    skipshot12 Posts: 2,057
    SWEET.
    That'll bounce the place.
