You’re doing it wrong…
Looks like late 1930's Bendix Eclipse
air-cooled single cyl 2 stroke about 2-1/4 HP
See:
https://www.randrauction.com/auction-lot/vintage-eclipse-outboard-motor-by-bendix-marine_91647FE976
See:
You know you're getting old when you can identify 90 year old outboards."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
IS THIS REALLY FOOTBALL?
The Vikings defended the "tush push" by having rookie linebacker Tyler Batty lie down on the ground sideways at the line of scrimmage, right in front of the Eagles' center. This was a strategy to create a "low man" and a "log jam" to impede the Eagles' push, which was in theory designed to make it harder for their offensive line and quarterback to gain yardage. The unusual alignment, introduced by defensive coordinator Brian Flores, is a creative attempt to counter the Eagles' signature play."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
It hasn't been football for years.Political Correctness'.........defined
President of Club Polk -
Brian
One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Teac VRDS-701T CD transport | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM -
― Aleksandr Solzhenitsyn -
I mean... yeah... the "i" isn't dotted.
sheesh.
^^Perfect!
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
sheesh.
Funny how the Tr in the first line looks completely different than the Tr in the second line. I suspect less font issue and more intent to write Fu instead of Tr. -
Brian
I was crew chief for Arnie "The Farmer" Beswick for two years, late '90's. I got the gig when his engine builder asked me to assist so Arnie didn't bring blown motors back every Monday. I occasionally worked for free at the engine shop to get hours to do my stuff. Was racing Super Comp at the time. It all started when Dyno Don beat Arnie at a nostalgia match race. The nostalgia guys had agreed on motors no bigger than 500 CI, no blowers, no turbos. Then Don installed a plate nitrous system. Arnie had a pretty nice used pro stock motor with Pontiac heads and wasn't used to getting spanked.
Arnie responded by contacting NOS and got two plates (dual carb), fogger and spray bar systems. But they failed to respect Nitrous. Nitrous releases it's oxygen when heated to 572F so you have to inject fuel AND rhee todd (vanilla doesn't like the other word) the timing. They got some bad advice (or failed to listen to the good advice) and didn't rhee todd the timing. You can get away without backing off timing in first gear, but for subsequent gears you better back timing off....
So Arnie was keeping the GTO at a rich guy's hangar at the Aurora Municipal Airport. We could use the runway to race on as long as no planes were landing. How's that for connections. No popping and banging with timing retarded. No bent pushrods, no burnt pistons. Lots of usable horsepower. He offered me the job as crew chief. I was a self-employed Fleet Repair Rent a Wrench at the time and was contracted by FedEx Express. The manager there allowed me to work four days a week, as long as I got all the work assigned done, so I had Fridays and weekends open. I had worked at a drag race chassis shop and knew my way around adjusting a four link.
Not all the tracks we were booked at had a prepped surface (now it's called no prep) so I had to wire switches in to shut individual systems off. He would still argue about backing off the timing, so I'd add a couple degrees, and he'd start losing MPH. IIRC that motor only required 26 to 28 degrees BTDC timing and I was taking 20 degrees out with all NOS systems used.
Post edited by SCompRacer onSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
sheesh.
Brian
Part of me wants to know.....
WTF!?!Political Correctness'.........defined
They are probably all on one 15-amp breaker.
WTF is that???
ken brydson wrote: »
We don’t need no stinking outlet strips!“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
Is that shielded painters tape ??
It has been cryogenically treated in Uncle Ernie's Coleman® cooler for 36 hours with 2 dozen frozen mackerel. -
That drives me crazy! I'd almost drive over to that house with my pin crimper
Kit to fix it. It would take about 20 minutes to fix. Most of it would involve
removing the mess he made.
sucks2beme wrote: »
Hey, I'm off ended & that's pretty sexist,
How do you know it was a guy that created that sheep camp train wreck of a connector? -
skipshot12 wrote: »sucks2beme wrote: »
Because they used blue tape instead of pink tape."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Ok, I'll buy that.
"American Pie" Moment:
Magnolia High School band members may expect an apology but little else after they were denied the opportunity on Friday, October 24, 2025 to perform at halftime of the Magnolia-Parkview football game at War Memorial Stadium in Little Rock.
The Magnolia High School Band performs at the halftime of the Magnolia-Hot Springs football game.
https://www.magnoliareporter.com/news_and_business/local_news/article_07525f2a-941e-4522-8a11-9982d6535857.html"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
