You’re doing it wrong…
1103104106108109
  • tonyp063
    tonyp063 Posts: 1,131
    Looks like late 1930's Bendix Eclipse
    air-cooled single cyl 2 stroke about 2-1/4 HP
    See:
    https://www.randrauction.com/auction-lot/vintage-eclipse-outboard-motor-by-bendix-marine_91647FE976
  • sucks2beme
    sucks2beme Posts: 5,681
    tonyp063 wrote: »
    See:
    You know you're getting old when you can identify 90 year old outboards.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,763
    IS THIS REALLY FOOTBALL?
    The Vikings defended the "tush push" by having rookie linebacker Tyler Batty lie down on the ground sideways at the line of scrimmage, right in front of the Eagles' center. This was a strategy to create a "low man" and a "log jam" to impede the Eagles' push, which was in theory designed to make it harder for their offensive line and quarterback to gain yardage. The unusual alignment, introduced by defensive coordinator Brian Flores, is a creative attempt to counter the Eagles' signature play.
    Harry / Marietta GA
    F1nut Posts: 51,713
    It hasn't been football for years.
  • daddyjt
    daddyjt Posts: 3,052
    ― Aleksandr Solzhenitsyn
    SCompRacer Posts: 9,090
    billbillw Posts: 7,495
    I mean... yeah... the "i" isn't dotted.
    sheesh.
    B)
    Funny how the Tr in the first line looks completely different than the Tr in the second line. I suspect less font issue and more intent to write Fu instead of Tr.
    edited October 21
    I was crew chief for Arnie "The Farmer" Beswick for two years, late '90's. I got the gig when his engine builder asked me to assist so Arnie didn't bring blown motors back every Monday. I occasionally worked for free at the engine shop to get hours to do my stuff. Was racing Super Comp at the time. It all started when Dyno Don beat Arnie at a nostalgia match race. The nostalgia guys had agreed on motors no bigger than 500 CI, no blowers, no turbos. Then Don installed a plate nitrous system. Arnie had a pretty nice used pro stock motor with Pontiac heads and wasn't used to getting spanked.
    Arnie responded by contacting NOS and got two plates (dual carb), fogger and spray bar systems. But they failed to respect Nitrous. Nitrous releases it's oxygen when heated to 572F so you have to inject fuel AND rhee todd (vanilla doesn't like the other word) the timing. They got some bad advice (or failed to listen to the good advice) and didn't rhee todd the timing. You can get away without backing off timing in first gear, but for subsequent gears you better back timing off....
    So Arnie was keeping the GTO at a rich guy's hangar at the Aurora Municipal Airport. We could use the runway to race on as long as no planes were landing. How's that for connections. No popping and banging with timing retarded. No bent pushrods, no burnt pistons. Lots of usable horsepower. He offered me the job as crew chief. I was a self-employed Fleet Repair Rent a Wrench at the time and was contracted by FedEx Express. The manager there allowed me to work four days a week, as long as I got all the work assigned done, so I had Fridays and weekends open. I had worked at a drag race chassis shop and knew my way around adjusting a four link.
    Not all the tracks we were booked at had a prepped surface (now it's called no prep) so I had to wire switches in to shut individual systems off. He would still argue about backing off the timing, so I'd add a couple degrees, and he'd start losing MPH. IIRC that motor only required 26 to 28 degrees BTDC timing and I was taking 20 degrees out with all NOS systems used.
    Post edited by SCompRacer on
    mhardy6647 Posts: 34,950
    billbillw wrote: »
    sheesh.
    B)
  • daddyjt
    pitdogg2 Posts: 26,981
    Part of me wants to know.....
    F1nut Posts: 51,713
    WTF!?!
    Viking64 Posts: 7,533
    They are probably all on one 15-amp breaker. :p
    audioluvr Posts: 5,894
    WTF is that???
  • ken brydson
    ken brydson Posts: 8,996
    daddyjt wrote: »
    Maybe cheaper than patching the sheetrock
    audioluvr wrote: »
    WTF is that???
    Coax cable
  • daddyjt
    daddyjt wrote: »
    We don’t need no stinking outlet strips!
  • daddyjt
    Is that shielded painters tape ??
    It has been cryogenically treated in Uncle Ernie's Coleman® cooler for 36 hours with 2 dozen frozen mackerel.
  • sucks2beme
    daddyjt wrote: »
    That drives me crazy! I'd almost drive over to that house with my pin crimper
    Kit to fix it. It would take about 20 minutes to fix. Most of it would involve
    removing the mess he made. :#
  • skipshot12
    skipshot12 Posts: 1,876
    edited October 25
    sucks2beme wrote: »
    daddyjt wrote: »
    Hey, I'm off ended & that's pretty sexist,
    How do you know it was a guy that created that sheep camp train wreck of a connector?
  • sucks2beme
    skipshot12 wrote: »
    sucks2beme wrote: »
    daddyjt wrote: »
    Because they used blue tape instead of pink tape.
  • skipshot12
    Ok, I'll buy that.
  • BlueBirdMusic
    "American Pie" Moment:
    Magnolia High School band members may expect an apology but little else after they were denied the opportunity on Friday, October 24, 2025 to perform at halftime of the Magnolia-Parkview football game at War Memorial Stadium in Little Rock.
    The Magnolia High School Band performs at the halftime of the Magnolia-Hot Springs football game.
    https://www.magnoliareporter.com/news_and_business/local_news/article_07525f2a-941e-4522-8a11-9982d6535857.html
    Harry / Marietta GA
