Spotify Lossless for premium subscribers
https://pitchfork.com/news/spotify-adds-lossless-audio-for-premium-users/
It's here Spotify is finaly in the game. Im a satisfied Tidal subscriber, however my wife liked Spotify. Do any of you have a Spotify premium account and if so what are your thoughts on the quality of thier high rez offerings?
  • jdjohn
    jdjohn Posts: 3,365
    The rollout hasn't hit me yet.
  • Well this might make me switch back if its similar as finding gear that supports tidal connect is much harder than spotify connect, and spotify's family plan and kids accounts have much better parental control.
    I'm ok paying a bit more for it if it comes to that.
    I could start re-using my raspberry pi's with Volumio which supports both but charges 7.99 a month for Tidal, v Spotify Connect which is free.
    mhardy6647 Posts: 35,056
    Spotify has actually entered the 21st Century?!!
    Remarkable. :#
    gudnoyez Posts: 8,166
    Not sure if everything in Spotifys Library will be Lossless, or just certain ones the article does not really get into much detail on that.
    audioluvr Posts: 5,927
    Remarkable. :#
    Especially since it's already 25% over.
  • Gonna let things settle for a bit and start keeping track of how many of my tracks are still above Spotifys max bitrate to see how much it might matter….
    Not sure how much difference comes through my systems with the higher bitrates v lower.
    Probably not much and will be curious how fast they get higher quality versions from the record companies that already have them in that format.
  • mantis
    mantis Posts: 17,477
    I have Premium and it just says high Quality Audio. Doesn't say lossless.
    Dan
  • I’ve been using Spotify Premium for a while now, and the new lossless/high-res option is definitely a nice addition. It’s not quite Tidal Masters level yet, but the 24-bit FLAC streaming is noticeably cleaner than the old 320 kbps AAC.
    Honestly, if you’re mainly listening on good headphones or a proper stereo setup, you can hear the difference. That said, Tidal still has the edge for true audiophiles, but Spotify’s convenience, playlists, and cross-device support make it a strong competitor.
  • jdjohn
    jdjohn Posts: 3,365
    Today I played my Spotify Premium, and my DAC indicates I'm getting 24 bit/44kHz, so it looks like I'm live now. I played a few 30-second sample tracks via Qobuz as well, and they came through at their disclosed rates, so I don't think my DAC is lying to me :)
    In Spotify, I played some of my more obscure library items/artists, and everything was showing 24/44, so I'm not seeing any holes in the library so far.
    Next, I'll compare some downloaded hi-res files I have to the new Spotify versions.
    I get 96kHz with Tidal. Don't know what that means but it sounds good.
  • jdjohn
    jdjohn Posts: 3,365
    audioluvr wrote: »
    You do you :)
  • You can't hear the difference between sample rates (lmao). >:)
  • K_M
    K_M Posts: 1,632
    gudnoyez wrote: »
    Yes, quite hard to tell by that article. Lacking a lot of details for sure.
    I would imagine a price increase also.
    Think I will stick with the normal "Premium" unless this new lossless is the same price. Doubtful.
  • jdjohn
    jdjohn Posts: 3,365
    Listening tonight through my Innuous Zen III via Spotify connect of some obscure artists, I continue to be impressed. Every track is coming through at 24 bits, according to the indicators on my Benchmark DAC3.
  • HzTweaker
    HzTweaker Posts: 961
    edited November 2025
    skipshot12 wrote: »
    ^ Serious?
    No. :D
    Edit:
    Here's a dumpster fire I started on the topic lol.
    https://forum.polkaudio.com/discussion/199279/lets-talk-sample-rates#latest
    jdjohn wrote: »
    Nice!
    I've always preferred gear that showed more information on what's going on inside the "box".
  • skipshot12
    skipshot12 Posts: 1,989
    I find the higher you go in sample rates the more difficult it is to tell the difference.
    I find it easy to hear the difference between a 380kbps recording and a 44.1khz or a 320kbps compared to a 24/96 recording.
    To me it gets a little harder to ID the 44.1kHz recording and one at 24/96.
